handling
Old Mar 28, 2008 | 07:36 AM
  #141
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
Default Spreader bar
OK, so I'm getting an alignment done this weekend. What's the preferred procedure with the spreader bar? Set the front and then put the bar back in and snug it up, or...?
Old Mar 28, 2008 | 08:27 AM
  #142
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
Originally Posted by TheSkunkWorks
Alum or steel blocks? My steel Guldstrands use 1/2" bolts.
My VBP blocks were steel with two 5/8" bolts. Not sure why they felt 1/2" weren't good enough. Maybe they wanted to increase the torque load on the bolts to put more clamp load on the joint for good measure.
NMsharkracer,
I just install my spreader bar with the car sitting on the ground after the alignment. Tighten it by hand until it is snug, then give it a little preload with a wrench (not enough to change the alignment).
Old Apr 3, 2008 | 01:54 AM
  #143
00fxd's Avatar
00fxd
Got my Gulstrand blocks in today. 1/2 grade 8's. It came with instructions for both 1/2 and 5/8 bolt instalations.
Frank
