275 tires
Old Mar 25, 2008 | 10:06 PM
LanceB's Avatar
LanceB
Default 275 tires
Before I knew as much as I do now (and when I actually trusted "experts" with my car for some reason), a tire place recommended BF goodrich 275's for my 81. They look great and it has been 2 years since I purchased them, but too late I realized they rubbed in places. I ended up having to move the parking brake for the rear (which cleared the rubbing there), but if I steer too sharp, the front still rubs somewhere inside the wheel well. As frustrated as I am, it is my own fault for not researching, driving, and testing the tires more before it was too late to take them back and downsize. Other than having to be careful when steering, can I cause any damage to anything up front besides the tire? If anyone has any recommendations or advice besides buying 2 new tires please advise. I am sure I screwed up though. I am suspicious and second guess everyone with my vette now. I REALLY wish I knew what I know now back then...
Old Mar 25, 2008 | 10:10 PM
LanceB's Avatar
LanceB
This was also before I found this forum too. Now I check with real experts before I do anything, not some bozo selling me tires. They probably saw there was a problem and just didn't want to say anything because they would have to remount tires. They probably knew I didn't drive it much and wouldn't realize till later down the road. I still know where the store is too. I will never go back there again. If anyone wants a set of 275's with about 3K miles on them, I have a nice set.
Old Mar 25, 2008 | 10:29 PM
thrilher's Avatar
thrilher
my '79 takes "if i remember right, its in storage" 225's on front and 235's on back. Was told on this forum that it varies with each car because they're all finalized individually and it varies .When i bought my car the tires rubbed in turns onto high curbs etc. I have since found out i had a stud missing from my lower driver A-arm and after repairing that mine haven't rubbed since. Also you have to consider the rims, backspace,width etc. i wanna say my rims are 8"width with 3.75 backspace..backspace is the distance between lug holes and the inside edge of the rim.
You shuold be able to see where your tires are rubbing and make a decision on the damages.Your tires sound like they may be a little big to me. Someone else may have experience with trying that size tire
Old Mar 26, 2008 | 11:16 AM
jbroughton's Avatar
jbroughton
Shouldn't hurt anything, as long as the tire isn't rubbing against anything sharp that would cut it. If it's only rubbing at full-lock of the steering wheel, it's a low speed thing anyway... might rub a shiny spot on the inner fender or something, but you should be ok.
Old Mar 26, 2008 | 12:21 PM
7T1vette's Avatar
7T1vette
Sine the tire store recommended them, why didn't you take them back and have them put a smaller size on?
Old Mar 26, 2008 | 01:04 PM
LanceB's Avatar
LanceB
I don't know why I didn't take them back way back then. It took me awhile to realize there was a problem. I see a shiny spot on the inside of the wheel well, but so far no damage. I guess I could always keep this set as spares for the rear in the future and eventually get a correct set for the front. I do like the wide tires, I need to move the parking brake bracket and re-install the parking brake cable to really make them work in the rear.
Old Mar 26, 2008 | 02:19 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Are these 275/60/15 or 275/50/15 series, your only saying 275..?
Old Mar 26, 2008 | 03:48 PM
Jims79's Avatar
Jims79
NOT TRUE. You should be ok in the rear moving the e-brake but if you ever have to turn hard and need to hit the brakes and/or do so on rough roadway you can do a lot of damage to the front fenders. A LOT. more then a set of tires would be. I would swap out the front tires for either 255/60/15's or a 245/60/15. Take the vette to another tire shop & have them mount a 255 first if you can full-turn the wheel from side to side on the ground w/out rubbing then go for the 255's. if you rub drop down to 245's less then an 1 inch smaller in width. Don't go 235/60's they are too small. however you could put a 225/70/15 on the front 'stock size' & it should be the same diameter as the 275/60's in the rear. maybe .06 of an inch taller in the rear.
Old Mar 26, 2008 | 08:40 PM
LanceB's Avatar
LanceB
275/60/15 sorry I didn't clarify that.
Old Mar 26, 2008 | 09:42 PM
everest29's Avatar
everest29
Without mods, the largest you can run is 235-55 in the front and 255-50 in the back. Incedentily, these sizes will also provide you with a tire (27") that is exactly the same heigth as the original/stock tire, just wider. In the front you are probably rubbing against the frame. Jack the car up and crank the wheel all the way over and spin the wheel with your hand while laying underneath. My bet is that it is the frame the tire is rubbing against, which wouldn't cause too many problems. Just don't crank the wheels "lock-to-lock". You aren't going to turn a car as long as a Sting Ray around in one shot on a normal street anyway. So the extra turning radius you will be missing isn't going to make that much difference.
Old Mar 26, 2008 | 09:55 PM
Jim_Harrison's Avatar
Jim_Harrison
Exactly where are the tires rubbing? My 295/35/17's rub on the front part of the frame and sway bar, no sharp areas, so did my 275's? Hasn't hurt a thing in thousands of miles of street use or AutoX time. My rears use to rub on my exhaust pipes. A two lb sledge hammer fixed that.
Old Mar 26, 2008 | 09:58 PM
Glass Act's Avatar
Glass Act
To be safe I'd say 245/60/15 or 255/60/15. Wish I could offer you a 100% size, I run 265/50/15 front and 295/50/15 back and have no issues at all on our 79 with stock trailing arms. But again my suspension is all new, which might account for a different height.
Good Luck
Old Mar 26, 2008 | 10:28 PM
sassc3's Avatar
sassc3
man after my own heart...if is not too much to ask...what offset and/or backspace and if you don't mind, what make/model of wheel and tire...and how about a nice side shot pic of your 72? PLEASE!!
Old Mar 27, 2008 | 01:19 AM
spike1360's Avatar
spike1360
I'm also having rubbing problems with my 255/60/15s, thinking about downsizing in front.
Old Mar 27, 2008 | 01:32 AM
OzzyTom's Avatar
OzzyTom
I'd be very worried if you have any potential clearance issues at the front in particular!
Whilst you might be able to get full lock to lock when stationary, the dynamics change a great deal when there is cornering G's and/or bumps in the road.
One of our club members learnt the hard way..... He just fitted some beautiful new wide tyres all round on his 69 vert, and subsequently ripped his front fibreglass guards when negotiating a carpark turn at full lock and didn't see a pot hole. He wasn't going fast, but the nice new tread pattern clearly grabbed the guard edge on the rebound from the pot hole, and ripped it.
Old Mar 27, 2008 | 02:01 AM
69elky's Avatar
69elky
You did not say if your rims were after market,different offset.Factory tire size was 255/60/15 all around.Your front wheel wells are relieved for the 255's.Earlier cars were not releived for the wider tires and needed to be modified to accept them with the stock offset rims.Later Geno
Old Mar 28, 2008 | 09:36 PM
LanceB's Avatar
LanceB
So could I get (2) 255/60/15's and replace the tires in the front and keep the current 275's in the back on my 81? I don't have any rubbing issues in the back now that I moved the parking brake. I just wonder how it affects ride height. I could keep the 275's and drag race the spares or I could see if the original tire place that sold them to me in 2002 would make a deal for the 255's. I found the reciept and I had 85,500 miles on it when the tires were purchased. I now have 89,000. They didn't check for rubbing, I haven't driven it enought to notice. What do you think? I don't drive it enough for sure. They are BF Goodrich so new ones should match as far as the logo.
To 275 tires
Old Mar 29, 2008 | 08:48 AM
fugawi's Avatar
fugawi
i got 255/60 on back, and 245/60 in front. very satisfied. norub on full lock turn..
Old Mar 29, 2008 | 12:54 PM
Jay-Dog's Avatar
Jay-Dog
'76 w/ 255-60-15 BFG's. No rubbing front or rear.
Old Mar 29, 2008 | 01:27 PM
LiveandLetDrive's Avatar
LiveandLetDrive
My 275 60R15's also rubbed on the frame right near the heads of some round-headed bolts, this never concerned me. The only problem I had with the 275's is that they looked like (and actually were) light truck tires.
255 60R15 was a factory optional tire size after some mid-year so unless you've got an early C3 there is no reason these should be a problem front or rear.
