Tire size
Old Apr 2, 2008 | 08:00 AM
redwingvette's Avatar
redwingvette
Default Tire size
I am replacing my old Goodyear ST's 225/60-15's with BF Goodridge Radial TA's 235/60-15's.
Do I need to be concerned about the speedo difference?
Old Apr 2, 2008 | 09:41 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
The 235/60/15 tires will be 1.8% slower, so at 60 mph your really doing 61.1 mph.
Old Apr 2, 2008 | 09:47 AM
BB72's Avatar
BB72
Try this site, if the tire height is the same there's no speedo change.
http://www.1010tires.com/TireSizeCalculator.asp
It looks like 245/55-15 will fit, it's 25.6 tall like your original size. The 235 size is taller and will actually read low on your speedo. 245's should fit since 255's used to come OEM. But don't take my word for it, check with the shop your going to deal with, their books will tell you.
Old Apr 2, 2008 | 12:28 PM
7T1vette's Avatar
7T1vette
No.
Old Apr 2, 2008 | 01:54 PM
Jims79's Avatar
Jims79
Not between those two size's.. Question why not run the correct size tire to start with? Both the 225/60 & 235/60 are smaller tires. I would either run the original 225/70/15 or 255/60/15 my .02
Old Apr 2, 2008 | 06:59 PM
redwingvette
The car had the 225/60's on it and the trans speedo gears are setup for them. I also had a little front fender rubing issue and a bigger tire would make that worse. I do not believe the fenders are original and think that is why I had the rubing issue.
Thanks for your imput. I will not worry about it any more.
To Tire size
