frame mod, powder coating
Old Apr 18, 2008 | 09:05 PM
Greg73convertible's Avatar
Greg73convertible
Default frame mod, powder coating
Last min got offered use of garage, was going to pull all suspension off and put new vbp stuff, might as well take body off .
I have
73 convertible
tpi ,crate motor
700r
full package vbp suspension 17 & 18 in wheels
1 what mods (I don't care about stock) should I do to the frame I am hoping to get some pics, take frame to a welder and ask them to "weld this"
2 sandblast vs acid dip
3 powdercoating best way to go ?
Thanks for your help
Old Apr 18, 2008 | 10:29 PM
vettesbydesign's Avatar
vettesbydesign
I have
73 convertible
tpi ,crate motor
700r
I don't knoiw if I can help,but will try....
Your frame would be fine for the combo that you have,if it is solid,so doing mods would....yes strengthen it up some,but really not warranted.I have the inside of my frame rails treated w/rust incapsulator,then sandblasted,and powder coated.
I mjust took a modified 68 frame to the place yesterday that I use local,and should have it back for next week.
The frames are 2 pieces,and stitch welded......I welded the frame up complete,added gussets,and added reinforcements since it was a early 68 frame...at the kick ups,and made the crossmember removeable.This is for a 550 horse + BB,5-speed road raced themed car tho,so the extra strength is warranted,even tho started w/a perfect 68 frame.
Hope this helps some.These frames are pretty strong from the factory,bud. They held all the high horse BBs,and SBs out the assy plant's doors.....
here's a stock 69 vert frame...treated,sandblasted,and powdercoated semi-gloss blk......
Old Apr 19, 2008 | 08:05 AM
Alan 71's Avatar
Alan 71
I stripped the frame my self and then had it powder coated. It was done in semi-gloss but was a little too shiny for a 'stock' look so I lightly sanded the surface with 400 and painted it with Krylon. It's held up really well and hasn't needed to be touched up. The powder coating seems to have made the Krylon more durable.
Regards,
Alan
To frame mod, powder coating
