Rear window storage - '72
Old May 4, 2008 | 10:27 AM
alanbl's Avatar
alanbl
Default Rear window storage - '72
It was almost 2 years before I discovered the "secret" drop down shelf that holds the rear window in my '72! Now that I'm finally on the road again after working on her for a year, I"m wondering if there should be some sort of padding or vinyl insert to hold the window in place on said shelf. Right now it's just hard metal. ???????
Thanks!
Old May 4, 2008 | 12:24 PM
early shark's Avatar
early shark
alanbl,
The '72 window storage tray is molded fiberglass. It has a shaped sunken area that the window resides in. At the back of the tray near the cargo courtesy lamp location is a rubber coated bracket that the 'frame' portion of the window is fit into, so that the window is securly held in place and won't move around. There is no need for anything else.
Old May 4, 2008 | 01:06 PM
CCrane65's Avatar
CCrane65
early shark, I don't know about yours but mine rattles while driving so I put some 1 inch wide weather strip foam around the edge to keep it quiet. It sticks very tightly in the factory rubber coated bracket but it still made rattling noises around the edges.
cc
Old May 4, 2008 | 02:36 PM
Alan 71's Avatar
Alan 71
For my 71 I always put a towel under the window to give it some padding and to stop the rattle.
Regards,
Alan
Old May 4, 2008 | 05:03 PM
7T1vette's Avatar
7T1vette
Soft weatherstripping foam is a perfect choice to solve that problem. You may only need a few pieces, rather than put it all the way around.
Old May 4, 2008 | 10:48 PM
Artsvette73's Avatar
Artsvette73
cc
There should be two rubber bumpers on each end. I think the bumpers used in the rear compartments are the same. Mine rattled put the bumpers on and it solved that.
Old May 4, 2008 | 10:49 PM
Artsvette73
cc
There should be two rubber bumpers on each end of the shelf. I think the bumpers used in the rear compartments are the same. Mine rattled put the bumpers on and it solved that.
Old May 4, 2008 | 11:09 PM
CCrane65's Avatar
CCrane65
I do have the bumpers on the tray (although the drivers side bumper keeps getting knocked out and has to constantly be re-installed). There is no rattle when the window is not in the tray.
cc
Old May 4, 2008 | 11:12 PM
alanbl's Avatar
alanbl
No rubber bumpers on mine. I used a towel today - worked great! Are the bumpers available from Zip or someone else? Yes, I'm just asking here instead of doing my own search.
Old May 5, 2010 | 01:09 PM
kansas123's Avatar
kansas123
Default no rattle when up
Mine doesn't rattle much until I hit a bump or two and the stupid tray drops down. Without the window in it the tray stays up fine; have not investigated further but might try locking the tray to see if it keeps it from falling; or look to see if there is an adjustment of some sort...
Old May 5, 2010 | 01:33 PM
Brooklinite's Avatar
Brooklinite
The catch on the tray is identical to the ones in your storage compartments. You might try swapping to see if that helps. I swapped mine because the one on the tray had a groove worn in it from years of rubbing on the striker. I had to push up on the tray before I could push the button.
Old May 5, 2010 | 04:34 PM
MakoShark72's Avatar
MakoShark72
Doc Rebuild carries all the little rubber bumpers, stops, pads, etc....
See this thread, post #20 for pictures on when I restored my rear window tray...
http://forums.corvetteforum.com/c3-g...-question.html
Old May 6, 2010 | 12:44 AM
KSM's Avatar
KSM
Hear is how I handled the storage tray........I used the same material in the old cardboard glove box......I think this material worked out great.
It's a oil drip pad.......you are supposed to put it under the car to soak up drips so your concrete floor stays clean, It was cheep at Pep boys for a 3x3ft roll. The texture is vary soft,it reminds me of the grey trunk liners in some cars.
I just made paper templates of the tray and cut them out and spray glue to hold the down. I also used the rubber gasket on the lip.....all rattles gone.
The hold up handle is bent metal and can be adjusted not to drop.
Old May 6, 2010 | 01:01 AM
Peterbuilt's Avatar
Peterbuilt
How much more wind goes thru the car with the window out as opposed to in? Just curious since my window is fixed in place.
Old May 6, 2010 | 01:51 AM
Frogday's Avatar
Frogday
I don't really notice much difference whether the window is in or out.
Old May 6, 2010 | 09:39 AM
KSM's Avatar
KSM
I (also)don't notice a wind speed difference but I due notice a sound difference their is less wind noise at speeds under 50mph.
Old May 6, 2010 | 07:50 PM
Alan 71's Avatar
Alan 71
Hi,
The biggest difference I notice is how CLOSE the car behind you sounds!!!!
Regards,
Alan
Old May 6, 2010 | 07:56 PM
spinadog's Avatar
spinadog
The biggest difference I notice is how LOUD and cool my exhaust sounds...
To Rear window storage - '72
