Charcoal canister installation
Old May 6, 2008 | 03:36 PM
blckslvr79's Avatar
blckslvr79
Default Charcoal canister installation
I'm installing a charcoal canister back in my car. (Previous owner removed the original one.) The donor canister is from a 76 or 77 I believe. It has two vac ports on top and one on the bottom.
One on top is labeled Tank and other Carb. One on bottom has no marking. I assume the one marked Tank would go to the vent line to the tank. Where do I hook up the one marked Carb? Should it be "T"'d off the PCV line or to the carb? Where does the one on the bottom go?
I'm running an Edlebrock Air Gap and Holley 650, so originality and emmission legal is not a concern.
Thanks.
Steve
Old May 6, 2008 | 03:41 PM
eastltd's Avatar
eastltd
My 73 has three connections on top: Tank, Carb & PCV. There is a forth connection on the bottom which I assume is a drain. I haven't tried to connect it yet but I'll do some digging tonight to see if I can find some info that will help us both.
Old May 6, 2008 | 05:16 PM
Alan 71's Avatar
Alan 71
EASTLTD's guess was right, the bottom nipple has a piece of hose about 5" long and is just a drain.
Regards,
Alan
Old May 6, 2008 | 05:32 PM
7T1vette's Avatar
7T1vette
I don't know about your year's set-up, but my "Carb" line runs up to T in with the PCV valve on the rocker cover...then to the front base inlet on the carb.
Old May 6, 2008 | 05:56 PM
blckslvr79's Avatar
blckslvr79
Thanks for the responses.
I kinda guessed the bottom was probably a drain.
I'll hook the carb line up to my PCV line.
Thanks!
Old May 6, 2008 | 06:50 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
The 79 shop manual should have a diagram of where those hoses go.
Old May 6, 2008 | 07:00 PM
Peterbuilt's Avatar
Peterbuilt
Default Now I'm confused.
My 74 350 auto trans "T"'s with the EGR hose and is hooked to ported vacuum. Is this correct? PG.
Old May 6, 2008 | 08:42 PM
kansas123's Avatar
kansas123
.........and the bottom is a drain
To Charcoal canister installation
