Hydraulic Clutch
Old May 7, 2008 | 05:47 PM
JustinD's Avatar
JustinD
Default Hydraulic Clutch
Need to ditch the stock linkages. I was reading around and it appears people use the stuff from a 85 gmc truck.
If I bought
this
and this
Get a fluid tank out of a civic what else do I need to buy? How does the slave cylinder mount up?
Old May 7, 2008 | 09:11 PM
JustinD's Avatar
JustinD
I suppose I need a new fork also.
http://www.partsamerica.com/ProductD...pe=700&PTSet=A
Old May 7, 2008 | 10:07 PM
MN80Vette's Avatar
MN80Vette
Originally Posted by JustinD
Justin,
The links open to a prompt for zip code. Can you post pics of what you found? How much do those parts cost?
Never mind. The links worked.
I am planning to put in a Keisler hydraulic clutch kit when I put in a Keisler 5-speed, but I'm open to options if you find something that works well and saves some $$.
BTW, I live on the other side of the cities from you. Are you interested in showing your car at Car Craft Summer Nationals? I am hoping to get some more C3s there. Our son's car club (All In My Garage) gets the grass area next to the dyno trailer.
Old May 7, 2008 | 10:10 PM
72LS1Vette's Avatar
72LS1Vette
Are those parts from the 1-ton truck?
Rick B.
Old May 7, 2008 | 10:11 PM
JustinD's Avatar
JustinD
Ya, I would defiantly show up with my car for a day as long as it moves under its own power.
JustinD's Avatar
JustinD
Originally Posted by 72LS1Vette
Are those parts from the 1-ton truck? The Master Cylinder looks like it might not be the right one.
Rick B.
They are from a 1 ton. I picked up the slave cylinder the master cylinder and fork are going to be in tomorrow or Friday.
Old May 7, 2008 | 10:36 PM
zwede's Avatar
zwede
Here's the bracket I made for my slave cylinder. I'm using the stock fork, slightly modded for the heim joint.
Old May 7, 2008 | 10:39 PM
JustinD's Avatar
JustinD
That is very nice. I would like to do something like that. Where did you get the heim joint, and how did you get it on just thread the shaft that is under the boot?
How did you get the bleeder on top? did you switch the placement of it? Mine is in the other hole that you have the plug in.
Old May 7, 2008 | 11:18 PM
78Vette-SA's Avatar
78Vette-SA
One option I know some have used:
http://www.novak-adapt.com/catalog/kit_hcrc.htm
Old May 7, 2008 | 11:28 PM
JustinD's Avatar
JustinD
Does the throw out beaing ride on the pressure plate with that setup? The way it seems, is that the "relaxed" position of the slave cylinder is to have the rod all the way out.
Old May 7, 2008 | 11:31 PM
sly vette's Avatar
sly vette
Have any of you read berniesvette thread on the install of a T5 in the archives yet???
You will find your answers there!!!
Old May 7, 2008 | 11:35 PM
zwede's Avatar
zwede
The heim joint came with the speed direct clutch linkage kit. I salvaged various parts when I switched to hydraulics. I welded the end of the heim joint to the slave rod.
Dunno about the bleeder. That's the way it came?
Yes, with a hydralic clutch the TO bearing does lightly touch the pressure plate. But the force is so slight it doesn't hurt the TO bearing. The slave has an internal spring that pushed the rod out. By doing it that way the slave auto-adjusts as the disc wears.
Old May 7, 2008 | 11:39 PM
JustinD's Avatar
JustinD
Ok, so now I just need to find a heim joint locally and figure out the rest of the puzzle. Reading the archived t5 thread now.
Old May 8, 2008 | 12:27 AM
JustinD's Avatar
JustinD
Did alot more digging and still am unclear about how the master cylinder rod attaches to the pedal. Is it too long or too short?
Old May 8, 2008 | 10:47 AM
rj8806's Avatar
rj8806
Looks like a nice setup and I know alot of guys are doing similar setups with no issues. I would be concerned that the throw out is in constant contact with the fingers though. The mechanical bearing is not designed to be turning all the time. Even though you said it was "light contact" that is still enough to cause it to turn constantly which will the bearing out alot quicker than normal.
Is there no way to adjust it so that the bearing is not in contact with the fingers all the time? Is it because the throw of the slave pushrod is not long enough? Just curious?
Richard
Old May 8, 2008 | 11:29 AM
zwede's Avatar
zwede
My understanding is that all hydraulic clutch systems lightly press the TO bearing onto the pressure plate. If they didn't, they wouldn't be self adjusting and would have to add some kind of adjusting mechanism.
Yes, theoretically it shortens the bearings life. My guess is that even with the somewhat shortened life due to the light contact, the disc will wear out first.
Old May 8, 2008 | 03:28 PM
68 NJConv 454's Avatar
68 NJConv 454
I have the bell housing you speak of as well as the clutch fork & pivot stud from an 85 1 ton chevy truck for sale.
I was going to go this route before I bought my 509 with scatterproof bellhousing. I have the part #'s somewhere of the master & slave cylinder you need, then all you need is a rubber hose to the civic resoviour you speak of and 18" of coiled brake line to connect the master to the slave.
Let me know if you're interested.
To Hydraulic Clutch
Old May 8, 2008 | 04:07 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Originally Posted by MN80Vette
Justin,
Most chain parts stores do that on their websites - it's so they can check your local store stock.
Old May 8, 2008 | 05:27 PM
68 NJConv 454
If I bought
this
and this
I beleive those are the correct master & slave cylinders.
The bellhousing actually has a bracket cast into it to mount it to.
I don't have pics on my work computer, I do have them at home. Let me know if you would like pics.
Old May 8, 2008 | 08:05 PM
JustinD's Avatar
JustinD
I fabbed up a bracket today. Should work fine. If I need the bell housing I will let you know.
