Using A Oil Additive For Flat Tappet Motors?
Received 1,306 Likes
I went to my local independent auto parts house I have been dealing with for at last 25 years now and picked up a new WIX oil filter. He told me that in the last year or so all of the oil being refined for automotive use has been reformulated and that the Zink additive has been removed. Being that my car is a flat tappet motor to ensure that the lubricating properties are still there he suggested an additive at each oil change. He has been adding Lucas Engine break in additive that has TB Zink plus in his 1970 Camaro Z28. From what I understand, all the new cars are running roller cams and lifters and there isn’t any need to add the Zink to oil anymore.
Just wondering what others think.
I hate it when people give answers without facts. Yes, your parts man is right and no, he is not tring to increase sales.
Do some reading here:
http://www.zddplus.com/
If thats not convincing enough, call the tech dept at any cam manufacturer and talk with them about zinc.
Yes, your parts man is correct. Even the diesel oils recommended above are having their zinc removed. The only real choice left is additive. I use the Comp break in additive, as well as the usual Lucas Heavy Duty Oil Stabilizer I've always used. God bless, Sensei
St. Jude Donor '07
Get some ZDDP additive or use one of the numerous "older engine" oils that have become available. Heck, I can get single-weight non-detergent oil at Wal-Mart again, I hadn't seen that stuff in years.
I use the valvoline Vr1 racing oil. It does not have to meet emissions so the yleave most of the zinc in the oil. Not as much as it used to have but it has lived just fine in my motor. I ran a fairly stiff spring for a flat tappet cam and have for years with no wear issues. Yes most of the oils have hadthe zinc removed and anything you can do to have the zinc in it will help the cam out.
& yes your sales guy is correct so keep buying from him..
Reference Number: 5351879
Dear Mr. Long,
Thank you for contacting us about STP Oil Treatment. We always appreciate hearing from our consumers.
The STP Oil Treatment in the blue bottle does contain ZDDP. When you add one bottle of the oil treatment to 4 to 5 quarts of oil it will provide you the same protection as older motor oils once provided. The red bottle only contains slightly more. I hope this information helps you.
Again, thank you for contacting us.
Sincerely,
Patti Copper
Consumer Response Representative
Consumer Services
If you have additional questions or comments, please click here to respond to this email.
Dear Mr. Long,
Sincerely,
Patti Copper
Consumer Services
That's correct ... even the "new" rated CJ Rotella 15W-40 has plenty ... true Zinc's been reduced some but there's still plenty in newest CJ for flat tappet. Fill your flattappet crankcase w/ Rotella 15W-40 and don't look back. Just yesterday I spoke w/ our area's diesel expert and followedup w/ some Zinc chat (we've been talking this issue for at least 2 yrs) ... Mack still makes a flattappet diesel and even new CJ oil is working just fine. Same gent is primo flattappet circletrack motor builder and lotsa guys continue using CJ oil in those too & it's AOK.
Weather's changed but sky ain't falling ... again, fill w/ CJ such as Rotella 15W-40 and don't sweat it. If it's a flattappet rebuild being broken-in, fill w/ CJ & also add a bottle of GM EOS too just for breakin. FYI ... Rotella's about $10 per gallon at local walmart ... it's sold dang near everywhere.
ren80 (08-28-2021)
Castrol has a new Syntec 20W50, full synthetic, formulated with increased zinc levels specifically for classic cars. You can check out the specs on their website.
All the facts Here . http://www.chevelles.com/forums/showthread.php?t=195620
I checked the label, and it says nothing about the specific contents. But if the STP info above is correct, its a cheap additive to use at about 3 bucks for the blue bottle. A lot less than the GM EOS
The ORIGINAL and bestest
Toronto Events Coordinator
It's true, those with flat tappet cams need to use either an additive in regular oil, use diesel oil, or use a specialty racing oil to seriously reduce the risk of wiping cam lobes.
What I am saying is not hersay or second hand knowledge, this is first hand knowledge from me. Last week, my 3 year old ~15000 mile 406 wiped several cam lobes.........I figured since I had that many miles on it and it was broken in fine I had nothing to worry about, and DID NOT elect to use anything other than regular oil. I dropped my motor off at the machine shop yesterday for a tear down and inspection.
If you insist on using regular oil, also use the additives, believe me, it is very cheap insurance.
Read this:
http://www.compcams.com/Base/pdf/Fla...chBulletin.pdf
