68 year model?
Numerous 68-only parts, but any of these parts I have needed I have been able to find on Ebay, Vette-only salvage yards, Vette parts shops etc.
The items were refined on later cars they weren’t defects.
Here is a list of some of the items you may be referring to:
1. Exterior door handles thumb button is difficult to push...you will be getting the door for the ladies for sure.
2. Window tracks are not as precise as the newer cars
3. No map pouch on the pass side.
4. No door pulls to close the door from the inside, just a ledge to grip.
I'm sure there is more but it was 30 years ago and I only owned it for 4 months. Was a great car and everything worked nice just had some looseness and rattles.
Also dash lacked proper support and rear frame was void of kickouts. Other than that the 69 is close to the same.
Mine is pretty tight all the way around. It's a lot better built than the 78I owned. Tons of rattles and cheap plastic parts.
Kelly
1st C3 model
only C3 to have ignition in dash
only C3 to have unique push button door lock
only C3 to have 327 ci small block (rev harder than 350's
)very similar to '69, with same 4 slot shark gills in fender
but Stingray name was omitted for 1968... unique!
Same big block engine and trans options as '69 (inc L88)
Yes, it has been documented that quality control was an issue with the release of the new C3, but those issues have most likely been dealt with, or if you have a true survivor, are easy to rectify during a refurbishment. No negative points in reality.
Yes there are also one off parts.. especially the centre gauge cluster and A/C controls and vents (if installed). Not to mention the "jam" tin vacuum actuator for the wiper door. If NCRS judging is NOT in your plans, then it is a non issue. 69 components fit and are a cheaper functional alternative and available. But if you can source the correct parts, it adds value to what I believe will eventualy be the most sought after C3 model in years to come.....
If you are going to do some engine mods as indicated, then absolute correctness obviously isn't an issue. I believe in building them up to satisfy your needs and desires.... not to satisfy some pedantic judge who finds criticism in lack of overspray behind a water pump!
(but of course, I have no bias at all.....
There are days when I sort of would like that car back. Both the car and the engine in the book have long since disappeared. The engine was sold to a retired fireman in Ohio and the car went to upstate PA.
Richard Newton
How to Restore and Modify Your Corvette, 1968-1982
Kelly
Bryan
