Key warning buzzer switch? Doesn't exist?
Old Jun 12, 2008 | 08:09 PM
Overlord's Avatar
Overlord
From: Crush your enemies, see them driven before you, and hear the lamentations of the women TX
Default Key warning buzzer switch? Doesn't exist?
So, I've got the steering column torn down and ready to go back together finally. But.... the key warning buzzer has never worked - I think. I recall a black ground wire under the dash that buzzed when it was grounded. Perhaps the switch was the problem. Pulled the switch, trailing plastic pieces. Crap. Went to order a new one and can't find it.
Ecklers
Corvette Ignition Switch Key Warning Buzzer Switch, 1969-1978
* For Non-Tilt/Telescopic Steering Colunmn
Zip
69-79 KEY WARNING BUZZER SWITCH
(doesn't say on the page but I called. It's for non T&T)
Davies Corvette
1969 - 1979 Switch, key warning buzzer without tilt & telescopic column
Mid America
nope
Rik's
nope
Corvette Parts Catalog
nope
The Last Detail
nope
Volunteer Vette
IGNITION KEY WARNING BUZZER SWITCH (STANDRD COLLUMN)
Corvette South
nope
Corvette Central
IGNITION WARNING BUZZER SWITCH 1968-1982
($7.95 is a good price but doesn't look anything like mine)
Paragon
buzzer, yes, switch, no
Rowley Corvette
nope
Corvette America
nope
The ones that have the switch are for non T&T and less than $20.
The ONLY place I've seen it billed as FOR T&T is Dr Rebuild and they want $70 for NOS. No other kind.
Ignition key warning buzzer switch
69-76 Buzzer switch NOS 70.00
77-82 Buzzer switch 8.95
C'mon guys. Save me from paying $70 for a switch listed above for $7.95.
Does NO body really make this for the '75 T&T?
Old Jun 12, 2008 | 10:03 PM
bmotojoe's Avatar
bmotojoe
These people in Puyallup Washington have many new and used parts. When I went to there online order parts they listed used at $25.00. Looked up part number and found GR. 2.195 part number 7811093 for the 69-76 Wheel T&T. There was no picture available for this switch.
Also if you look at part number 7811092 this switch is for 1977-1982.
Both switches are for Wheel T&T
69-76http://www.pacvette.com/store/store....1093&submit=Go
77-82http://www.pacvette.com/store/store....1092&submit=Go
Hope this helps,
Brian
Old Jun 12, 2008 | 11:48 PM
Jim Shea's Avatar
Jim Shea
I believe that the GM switch number 7811093 is the correct key buzzer switch for a 1969 through 1976 T&T column. For $25 you better grab it.
Jim
Old Jun 13, 2008 | 12:01 AM
7T1vette's Avatar
7T1vette
On my '71, the warning buzzer is achieved by actuating the horn relay. The key switch must work, of course, but the signal needs to go through the door switch and on to the horn relay. The 'reed' switch in the relay is used as a pulsed vibrator when called for by the ignition key switch (when key is in the ignition and the door is open).
Old Jun 13, 2008 | 12:25 PM
Overlord's Avatar
Overlord
Hope this helps,
Brian
I suspect the first one to be what I'm after. The second PN doesn't look anything like the one that came out.
Called. Sadly it's not in stock and he doesn't know anyone replicating them. Theirs go back into rebuilt steering columns. I'll be in Florida next week. I seem to recall a wrecking yard that specializes in corvettes there. Lessee...... ah!
Corvette Generation
16541 US 301
Dade City, FL 33523
Nope, called there and they get $950 for a rebuilt column. If they don't keep the switches, they can't get them anywhere.
Going to have to look at other GM cars but the story might be the same. Trans am got hauled to the engine shop to swap Wednesday. I mentioned I had to go look for parts and the owner handed me an unknown GM steering column. I was able to pull a mighty nice sector gear and a few other parts out of it. Neither he nor I could ID the year or car it came out of.
That's true. During my searches, the door ajar switch was often referred to as a key buzzer switch. Haven't looked at my wiring diagrams yet but I know my door ajar light (currently replaced by a soft neon light in the gauge cluster and run thru a 12 pin plug) had not been working for a while. Perhaps my column switch implosion was a recent occurance.
Well, the search goes on.....
I suspect, with some time constraints, I will end up with a hole in the center of the steering column until I track one down. Should work fine without one until then.
To Key warning buzzer switch? Doesn't exist?
