There is very little difference between them. Jets and rods are likely different, and there may be some minor design differences for their respective applications. But you can rebuild the truck carb into a good performing carb that will function fine on your C3.
Rudy -
It depends on the year of the carb. Q-Jets in the years 1968-1974 had very little difference between the truck and car carbs. You can set up a truck carb to run as well as a car carb. Starting in 1975, the carbs changed. The truck carbs were given different booster venturies to improve fuel flow and throttle response in the very low rpm range (for lugging and towing). With the stronger metering signal from these boosters, the primary metering rods were also changed in their design: The truck metering rods have .036" diameter power tips to prevent the carb from going over-rich at WOT, whereas the car rods are .026. Installing the truck carb on a high-reving Vette engine proves a little difficult to tune in most cases, and I recommend avoiding these carbs for a Vette application. But the truck carbs do work very well on trucks...
Lars
Rudy,
Just for your future reference, I will always defer to Lars on the subject of Q-jet carbs....but thought I would let you know that most Q-jets of that vintage can be converted to most configurations required.
I have an 1980 L82, I was told that it came with a stock Q-jet part # 17080228. (currently has an edelbrock on it) Can any other Q-jets be used on it? I'm having trouble finding that exact one.
