How much does your C3 WEIGH?
#81
Oxana and I are waiting for the C7 ZO6 comes out, we're going to buy one about a year old.... First thing I will do is slap a super charger on it....
I want to do the bumper mod... How much did you loose with the front and rear bumpers removed? I will have Danny and Chris make me new aluminum ones to take there place, so I won't loose as much as you did, but still should lighten things up a lot....
Is panic's vette streetable though? Yours is.... And that means a lot.
https://www.corvetteforum.com/forums...loss-mods.html
Bee Jay
#82
The 68-73 frames weight about 290 pounds, completely bare. I think the later frames are about the same. The other bits and pieces put on weight fast. The differential (pumpkin) weighs about 92 pounds I think.
The AIM says that my 68 Corvette Convertible weighs 3050 pounds. If this is true, I'm probably at 2900 pounds. This is with spare tire delete (50 pounds), all aluminum brake calipers, composite rear spring (8 pounds instead of 41 pounds), aluminum heads, aluminum water pump, aluminum intake manifold, and aluminum wheels.
#83
Factory A/C, Powered Windows, Aluminum 3-core radiator, small block, iron heads, steel headers, no spare:
3,300 Lbs.
Now after my body off restoration I am sure I pulled 100lbs of crud out of the frame. Haven't weighed yet but I also have a carbon fiber monospring now
3,300 Lbs.
#85
I am converting to hooker header & side pipes now. That system with 2-1/2" sweet thunder inserts weighed 76 lbs. on my scale one header is 18 lbs. my hooker comp header is 12lbs. I have to remove the under car exhaust to weigh it. Soon!
#86
No sir it is not stock......but I have not tried to reduce weight. I have just set the car up like I want and that's what it weighs.
Its just an aluminum headed small block with a 4 speed. No A/C no power anything expect for power steering. It has different seats a 4 point roll bar. Now the car has lots of little things that are not on it that help with the weight. As I said it was not intended for weight reduction it is just setup to my liking.
There are something's I am changing that may add weight for safety so I will have to re weigh it when I am done. For example I am going bigger stronger parts in the rear and a dragvette 6 link. I also plan to put in a TKO 5speed
#87
The C7 Z06 has a supercharger. Go to my weight loss thread, it will tell you how much weight I loss with the bumper mods. Did you ever find an electric vacuum pump we could afford?
Bee Jay
Bee Jay
#89
I dropped at least 410 pounds of my 1980 ,, All in the suspension and removal of a/c ..spare tire / and a lot of other parts ,, Head light swap is 24 pounds alone brakes 88 control arms 12 .. spring swap to composite .. So I am hoping 3k with me in her I am 175lb ..
I will weight it when done and post results with a complete list of changes
#90
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
#91
Anorexic Vettes
Im a huge fan of throwing up weight from cars to improve acceleration, handling, braking, and MPG. I'm pretty sure most of us who own any year Vette don't primarily use them as a commuter car, so why not lose the heavy crap (creature comforts, etc) for some extra performance/fun! This was my main goal when building my 68. Every step I took in the build had weight loss considerations, as long as the parts did cost an absurd amount of money such as paying $1,200 for aluminum control arms to shave 8lbs. Some main weight reduction mods that I thought were worth it while still keeping the car mostly original looking were (These figures are my best guess without exaggerating, I wish I took the time to actually weigh all the parts);
-LS all aluminum engine with plastic intake, etc (dropped close to -200 lbs and gained more HP, MPG, and dependability)
-Plastic radiator and electric fans from LS donor car (about -20 lbs)
-T56 trans probably weighs as much as the OEM TH350
-80-82 aluminum rear differential and composite leaf spring (better ride and dropped maybe -80 lbs)
-Drop the spare tire and tub (how often do you have a blowout? -55 lbs)
-Wilwood brake calipers (stock ones have issues anyway -40 lbs)
-Alloy wheels (-40 lbs)
-Dropped all A/C and heater components (Its a driver's car not an office, about -80 lbs, or more if you consider the OEM A6 compressor)
-removed all windshield wiper components (who drives their classic in the rain? about -20 lbs)
-removed all headlight and vacuum parts/tanks. I made some fiberglass headlight cover molds to keep the look, and mounted small 3 inch driving lights in place of the front turn signals, and then mounted plastic turn signals behind the grills (about -40 lbs)
-tubular cross-members and bumper brackets (had to for the swap stuff anyway, about -25 lbs)
-80-82 style seats without power options (about -30 lbs)
There are probably close to half a hundred other areas where I dropped 100+more lbs from the car in smaller numbers that are more on the extreme side, but without costing extra money either. Someday when I get the time I can put together a more detailed list with more accurate weights, but I also need to pull onto a scale and see what it weighs (I'm hoping under 2,800 lbs)
#92
Go get it weighed and report back! If you actually got it under 2,800 pounds then congrats, that would be quite a fun car with LS power to boot!
#93
That's a pretty impressive list! I think the LS motor weight loss number is optimistic, I've been looking into doing an LS swap and from what I've been reading I would say you saved closer to 100 pounds, but I could be wrong! Lots of factors to consider there.
#94
82 with spare tire carrier out, 1/2 tank gas and my fat *** in it was 3,550lbs. She still ran 12.95 on a hurt motor though. No idea what the new motor will do, but looking for at least 12.50s or better.
#96
Received 1,136 Likes
I think Mike/69427 lives up north somewhere where gravity is way different.
My goal was to get under 3000#'s empty, which I did at 2996#'s (aluminum this, aluminum that, I don't need this, I don't need that). More realistically with a couple of cement bags for the driver and a full tank, and four corner weight scales I was pretty happy to see this
#98
Weighed the 73 today
1/2 tank of fuel. Car weighed 3100 lbs. exact on a certified scale. That includes the 6 point roll bar, 3 drive shaft and half shaft loops, frame boxing gussets and extra diagonal frame tubes to stiffen the works, full exhaust (30 lbs heavier than the side pipes) and some tools in the cargo area. Home made tilt front end, normal aluminum bits and pieces on the small block. I can get it to 2950 lbs but the $$ to do so are hard to justify.
#99
Last time the blue car got weighed it was 3030# with 5/8 tank, there was no top on car at all, full interior. Heads, intake, radiator, flywheel, and calipers are aluminum. Since then the top was reinstalled, headlights were swapped to the FIA style and a S/C was added to the engine. Need to get it weighed again. Now the 9-car fully loaded weighs in at a whopping 3510# with a half tank of fuel. T
