Ground points, where?
Old Aug 25, 2008 | 01:51 AM
kiretunk's Avatar
kiretunk
Default Ground points, where?
Can somebody tell me where all the ground point in the electric harness is?
I found one, under the headlight switch.
But I wonder if there also is one in front, near the horn? I found a wire there, which isn't attached to anything. The reason I ask, is because the dashboard and whole interior was removed before I bought the car.
And when I turn on the headlight, the indicators for turn lights in the dash, is lightning. The headlights is ok, but the turn light isn't working. But when I connect a "check lamp" to the wire from the relay to the steering column, then its flashing. I have read there maybe some grounding issues, so that is why I ask about the ground points.
Old Aug 25, 2008 | 01:59 AM
sly vette's Avatar
sly vette
You will have to invest in a schematic, my friend. There are alot of grounds on a plastic car!!!
Old Aug 25, 2008 | 03:43 AM
kiretunk's Avatar
kiretunk
I have 2-3 different sets of schematics, but I just wonder where exactly these points are located. Its difficult to tell, only looking at the papers..
Old Aug 25, 2008 | 05:37 AM
C4TOMCAT's Avatar
C4TOMCAT
Wilcoxen is offering a CD AIM manual and that shows all the locations you are likely to need....it is at a form member price...well worth it. check it out.
Old Aug 25, 2008 | 11:21 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
General C3 Gnding, points....verifiy all of these.
1. Battery to frame, about 12" from the battery.
2. Frame to starter/Block, Battery cable size.
3.Frame to Birdcage, about directly under the light dimmer,
(connects frame to Birdcage, via a small braided cable (Weak link!)
4. main inside harness cable to Birdcage, near headlight switch.
5. Front light harness, to frame.
6. rear light harness to frame.
7. Add a gnd from alternator to frame.
verify all are in place and good condition.
good luck...69VETT
Old Aug 25, 2008 | 01:31 PM
7T1vette's Avatar
7T1vette
The general rule for GM cars is that [solid] black wires are ground wires. (Striped black wires are not grounds.) And there are some junction connectors that you will see with several black wires connected together. To test if wire connector is grounded [or not], use an ohmeter to measure resistance between that wiring point and a known good ground....like the engine block, etc. With the ohmeter on its lowest scale, you should show no resistance (0 ohms) if it is a ground location.
To Ground points, where?
