First Start goes wrong with a FIRE (Video)
Old Sep 22, 2008 | 06:33 PM
MrGoFaster's Avatar
MrGoFaster
Originally Posted by windup
I think you have answered your own question.
If the problem is with the wire from the battery to the starter then thats why the link did not kick in.
Btw... did you ground one of the wires from the starter harness{the one with the fusible links in} to the bell housing or engine block?
I'm not sure I understand the concept of what a fusible link is & does then. Today is the first day I've ever heard of one. The picture I have in my head is a glass fuse inside a white piece of plastic that twists apart somewhere in the middle of a wire & I havn't found that in that area.
There is a small wire in that bundle connected to the bell housing. I was pretty careful to number every wire & hose with some masking tape when I pulled the old motor. Problem with that tho is that any mistake the previous owner/s made I've duplicated. For the most part the numbering everything has worked really well for 99% of the motor swap. Naturally that last 1% is the stuff my Haynes book becomes useless with because repeatedly it just says "installation is opposite of removal" Thats all well & good IF you know how it was originally installed correctly.
Old Sep 22, 2008 | 06:57 PM
saudivette's Avatar
saudivette
Log onto Doc Rebuild and buy one of his flash, colour wiring diagrams
Old Sep 22, 2008 | 07:00 PM
1nicecorvette's Avatar
1nicecorvette
a fuseable link is a plastic (link) inline with a power wire. if there is a larger voltage on the line then the wire can handle the fuseable link melts or breaks the contact. inwhich you will need to replace the link unlike a fuse. seems the volatage was much more then anything could handle and went right through all of it.
exact definition -- A fusible link is a device consisting of two strips of metal soldered together with a fusible alloy that is designed to melt at a specific temperature, thus allowing the two pieces to separate.
Old Sep 22, 2008 | 07:05 PM
Jclgodale3's Avatar
Jclgodale3
Originally Posted by MrGoFaster
I know I'm in over my head with this project. I don't know ANYBODY to ask questions, thats why I'm here. :o[/COLOR][/SIZE]
You know what? When I first watched the vid I, I said..."you gotta be sh@tten' me" But then I understood. Dude. Don't sweat it. There is absolutely no one here that hasn't been in the same boat as you and had the same type issue. You can't and won't catch everything the first time. I commend you for being prepared!
Old Sep 22, 2008 | 07:17 PM
...Roger...'s Avatar
...Roger...
Spend a few extra bucks and get a Halon extinguisher.They are much cleaner.
Old Sep 22, 2008 | 07:32 PM
MrGoFaster's Avatar
MrGoFaster
Thank you, I get that now. I was thinking of a replaceable inline fuse but this is a permanent inline wire that acts as a fuse. I gotcha
I'll look again now that I know what I'm lookin for.
What that in mind, I get why the fusible link didn't do its thing. The remaining strands of the wire were smaller than the fusible link & so it got hot instead & was going to be the point where it would melt through & because it had a rubber cover over it, it caught fire.
OK, seems like I did have the right idea on how to fix it then by just cutting the end off & putting the connector back on.
Old Sep 22, 2008 | 07:33 PM
BigBlockTank's Avatar
BigBlockTank
Change the entire positive caable from the battery to the starter. Don't (as everyone here says) Bubba that beoitch up again.
Old Sep 22, 2008 | 08:00 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
Originally Posted by yellow 72
"I saw somethin' white hot, and uh, if it's white hot it aint got no rubber left on that wire"
Priceless
Why be an asshat? The dude is just looking for some help here.
Old Sep 22, 2008 | 08:01 PM
70454Convert's Avatar
70454Convert
Once you've fixed the electrical problem, I'd suggest you don't just pour gas down the carb. Try filling the float bowls manually thru the vent tube. This will allow the carb to function properly until the pump is primed and refills the bowl. Your buddy looked like he poured gas right down the venturi's which will just pool in the intake and will guarantee a nice fire if there happens to be a backfire thru the intake.
Good luck.
Old Sep 22, 2008 | 08:15 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
If he's got the ***** to post that kinda stuff, i think he can handle a little ribbing.
Old Sep 22, 2008 | 10:19 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
ask any question, before you take action,
this place was more knowledge than a college.
prime the bowls like suggested thru the vent tubes,
then look down the carb, manually pump the accelrator until you see gas squirt out.
Now your ready to lite it up, after you double check wiring.
Old Sep 22, 2008 | 11:22 PM
SIXFOOTER's Avatar
SIXFOOTER
All a fuse link is is an undersized piece of wire on the end of a circuit. Typically its 2 sizes under what the tated load of the circuit is. Say you have a circuit wired with 12 gauge wire, the fuse link should be 14.
A fuse is used to protect against an overload, like putting to mush stuff on a single circuit.
A fuse link is there to protect the wire harness (and thus the rest of the car) in case of a dead short. The plastic piece on a fuse link is just a splice cover, the link is the wire itself.
Pouring gas in the carb might work, but there is a much better, safer way. I use a large syrenge, a turkey baster will work. Fill the float bowl thru the Air Horn vent on top of the carb.
Before attempting to start the car, static time the car. Park #1 at 10* or so before TDC and then set the dist right on the #1 terminal. Fill the carb bowl (2 or 3 ounces is all) and hit the key, it Will start.
Like this, mine after a year of work, fresh start and fresh top end;
Pay no attention to the fat guy
Old Sep 22, 2008 | 11:54 PM
  #33
dave_roads's Avatar
dave_roads
at least you found a problem that needs to be fixed without adding large amounts of gasoline to the situation. double check all the ignition electrical connections. distributor, coil wires, etc... if theres a unhooked coil wire something will fry because all the electricity has to go somewhere (or thats what some people told me when i fried a wire one time). the weakest link fries. pull a plug and lay it on the exhaust manifold to see if you get spark. good luck.
Old Sep 23, 2008 | 09:57 AM
  #34
BenUK's Avatar
BenUK
It's easy to laugh but I just learnt something by watching your video so I'll be better prepared when I come to restart my car after the body-off. I've got two extinguishers in the garage but I think I'll have a buddy on hand as well.
Old Sep 23, 2008 | 10:50 AM
  #35
MrGoFaster's Avatar
MrGoFaster
Now thats how its supposed to be done.
I know just enough to know it was not going to go that smoothly before I tryed it.
Turkey baster sounds MUCH safer. I'll do that for sure. The air horn vent, thats the hole on the top front of the carb that sticks up like a short pipe?
Static time the car. Another new term. I'll Wikipedia that. What I did was put marks on the distributor when I pulled it from the old motor so that when I switched it over it would be in the general area of where it needed to be so that I could adjust it with the timing advance light I just got.
I know that statement is about to upset some mechanics in here. Thats OK, I can take it, I figure how else am I going to learn except by doing. I'll be the first to admit I'm no mechanic & that this project is very ambitious for me.
Old Sep 23, 2008 | 11:04 AM
  #36
MrGoFaster's Avatar
MrGoFaster
Wikipedia doesn't have anything on static timing (surprising) but I found this how to do Static Timing on an MG on YouTube.
http://www.youtube.com/watch?v=hpp67aqwM2Y
Old Sep 23, 2008 | 11:13 AM
  #37
MrGoFaster's Avatar
MrGoFaster
The distributer has a place underneath for 2 wires to snap into it. I have one red wire snapped in it. There is no wire for the other hole. This is how it was with the other motor but that doesn't mean its right. Not 100% on if this red wire is even supposed to be in the right or left side.
To First Start goes wrong with a FIRE (Video)
Old Sep 23, 2008 | 11:37 AM
  #38
windup's Avatar
windup
GoFaster....look at this thread and read post #12 by Noonie,that post and that explanation save me from pulling what little hair i have left ,out by the roots.
http://forums.corvetteforum.com/show...ghlight=timing
Old Sep 23, 2008 | 02:33 PM
  #39
DC3's Avatar
DC3
A fuse link should actually be two "gauge" sizes smaller than the wire it is protecting. So, in your example, a 12 gauge wire should be protected with a 16 gauge fuse link. For example, our ammeter circuits are 16 gauge but the fuse link is a 20 gauge.
DC
Old Sep 23, 2008 | 02:55 PM
  #40
SIXFOOTER's Avatar
SIXFOOTER
DC
Thats exactly correct
