Engine Run Stand
Old Oct 12, 2008 | 06:35 PM
tobyte1's Avatar
tobyte1
Default Engine Run Stand
Well, here is the start of the engine run stand. Got the frame cut down and welded back together ( it was a cart than moved rolls of cloth around a textile mill). I have the motor mount plates cut, but have not put them on the 'stalks' yet. Right now, I plan on hanging a radiator up front with the fuel tank below it. It will also have a full set of gauges and throttle control above the rad. The battery is going to ride between the frame rails under the harmonic balance. I am trying to keep this thing as compact as possible( note the zero clearance on the header collectors...got lucky there). Anyway, now is the time for suggestions and comments. Thanks, tobyte1
Old Oct 12, 2008 | 07:30 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
One thing about engine test stands. They are good for checking for leaks etc. but I would not let it run too long on the stand. THe rings need to be seated and that has to be done with the motor under load which means in the car or on a dyno. One reason I never built one. With the roller cams nowadays I just fire it up let it get warm, check for leaks and let it rip, I had my new motor up to 5500RPM's with 2 miles on it while seating the rings
Old Oct 12, 2008 | 09:34 PM
...Roger...'s Avatar
...Roger...
That looks like one MrGoFaster's after the accident pictures.
Just kidden
Old Oct 13, 2008 | 11:22 AM
MotorHead's Avatar
MotorHead
Didn't mean to sound so negative, an engine stand has it's purpose, I am just trying to help you avoid any problems with a new engine down the road. Try Lars he has a nice little engine test stand
Old Oct 13, 2008 | 01:21 PM
lars's Avatar
lars
That's correct - Run the engine on the run stand long enough to verify timing, valve adjustment and to correct any leaks, but get the engine in the chassis and hammer it with a load as soon as possible to seat the rings - running it too long with no load can "glaze" the cylinder walls and cause the rings to never seat.
Also, your run stand may be over-kill - you don't need a motor mount plate or any forward supports on the engine - you can simply hang it off a bellhousing so you have unlimited access to the bottom and sides of the engine. Here is a photo of my run stand - I've run BB Chevys and 455 Pontiacs on it by simply swapping bellhousings - there are no engine mount supports or forward supports on it - the engine hangs just fine from a hard-mounted bellhousing:
Old Oct 13, 2008 | 03:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
One word for you:
WOW!
Old Oct 13, 2008 | 03:16 PM
Billysvette's Avatar
Billysvette
I have started and run to check engines on a regular engine stand,you know the stands that rotate your engine as you are building it,its so simple.
Old Oct 13, 2008 | 03:43 PM
SanDiegoPaul
Recipe for disaster in my opine
Old Oct 13, 2008 | 03:56 PM
tobyte1's Avatar
tobyte1
[QUOTE=lars;1567450053]That's correct - Run the engine on the run stand long enough to verify timing, valve adjustment and to correct any leaks, but get the engine in the chassis and hammer it with a load as soon as possible to seat the rings - running it too long with no load can "glaze" the cylinder walls and cause the rings to never seat.[QUOTE]
Thanks for the input guys. This is all I want the stand for. I build engines for a lot of people and it will make it much easier if I can run their engines before they pick them up. It will also be good to take to shows and swapmeets so potential buyers can hear an engine run before they buy it.
Old Oct 13, 2008 | 04:05 PM
Billysvette
Naw,done it plenty of times,it works great,just feed water and hook up a battery,and gas.Im not doing dyno pulls now,just checking engine before i put them in vehicles.
Old Oct 13, 2008 | 04:45 PM
jgrigg's Avatar
jgrigg
Not to hijack this thread, but How long is too long?? Does that mean you can't break in a flat tapet cam on an engine stand since you're supposed to run the engine for 20 Min varying engine RPM??
Thanks,
Jeff
Old Oct 13, 2008 | 05:28 PM
lars's Avatar
lars
I've run engines through the cam break-in period (about 20 minutes), plus the time needed to set timing, re-adjust hot lash, fix leaks, and set up the carb. Total run time on most of my engines ends up being about 45 minutes or-so before I go to the dyno or into the chassis for a few hard pulls on the rings. This has always worked well.
Old Oct 14, 2008 | 03:19 PM
jgrigg's Avatar
jgrigg
Thank You so much for the answer. I was beginning to worry about breaking in my cam.
Thanks again,
Jeff
Old Oct 14, 2008 | 05:29 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Years ago when I lived in DFW metro, I bought mine from a vendor's display at a local show. It has made life so much more convenient on initial cam break-in, tune and search for leaks.
This motor is ready to drop in the car and wire up to start for proper ring seating.
I have a large house fan to cool radiator if not running fan off the w-pump. Works fine for those 10-15 minute checks.
To Engine Run Stand
