headlight washers
Old Oct 22, 2008 | 07:07 PM
LT-1 kid's Avatar
LT-1 kid
Default headlight washers
hi, I was looking for a pic of a 69 headlight washer location, i think there are 2 per side, or if any body knows the location that would be great. thanks in advance, greg
Old Oct 22, 2008 | 07:37 PM
7T1vette's Avatar
7T1vette
Headlight washers were located top and bottom in the center of the headlight bezel (cover in front of the headlamps). There was a "D" shaped hole in the upper and lower portion of that bezel for the nozzels to fit into. It might get expensive to hook those suckers back up. [And if you don't drive in bad weather, I'm not sure when you are supposed to use them....]
Old Oct 22, 2008 | 08:08 PM
LT-1 kid's Avatar
LT-1 kid
thanks 7T1, i will give that a go,thats the last item on the 69, just want to keep it correct, kid
Old Oct 22, 2008 | 08:11 PM
Alan 71's Avatar
Alan 71
Hi Greg,
7T1 is right on.
To add a little to your question about location. I believe 69 had the nozzles in the vertical surface between the lights.
I believe 70 had 1 nozzle on the vertical surface and 1 on the lower horizontal surface.
So why does my 71, #6589 have 2 round holes in the vertical surface between the lights? Did St. Louis have some 69 bezels to use up? My car does have a 5 port pump and the cut off washer hoses.
Regards,
Alan
Old Oct 22, 2008 | 09:37 PM
Richard454's Avatar
Richard454
Here are some pics- Hope this helps-
Richard
Old Oct 22, 2008 | 09:53 PM
LT-1 kid's Avatar
LT-1 kid
thanks fellas for the info expecally the pics, also richard i like the paylin pic, she has my vote. kid
To headlight washers
