C3 New Frame
Old Nov 1, 2008 | 09:31 AM
gghg's Avatar
gghg
Default C3 New Frame
I have a 69 coupe and it looks like it has seen it's fair share of Canadian winters, lots of salt on the roads and it looks like it may have sat in some field for a while. The Frame is OK, some areas are a little thin nothing a weld in patch can't fix. I was wondering about a frame replacement. Has anyone replaced an entire Frame? Who is one of the better places to get one from? Anyone know of a fabricater in Eastern Canada (Ontario) or North Eastern States NY, Penn, Mich. Any tips on Frame replacement. And the big question any idea what it would cost.
Old Nov 1, 2008 | 10:40 AM
hwcoop's Avatar
hwcoop
I replaced my frame last year with another used 73 frame
http://coopersgarage.piczo.com/1973c...linkvar=000044
The cost depends on how much you can do yourself and how much shopping around/scrounging you can do.
You are much further ahead if you can do it yourself as I think shop rates would make it prohibitive to have it done in a resto shop.
The second problem is once you take it apart you will find yourself in the "While I'm at it" mode replacing all the bushings, brake,fuel lines, triling arms etc
Its getting tougher to find a good used frame these days though they are out there, If I could do it again I would probably go with a SRIII frame with C4 suspension.
http://www.sriiimotorsports.com/196382corvette.html
Or if you would like to keep it original you can check out various vendors by doing a google for "Corvette Frame"
http://www.tracyvette.com/frames.html
Old Nov 1, 2008 | 10:48 AM
Paul L's Avatar
Paul L
http://www.vetteproducts.net/
Old Nov 1, 2008 | 04:26 PM
Alan 71's Avatar
Alan 71
Hi GGHG,
I've looked at the frames that 'Vette Products of Michigan' builds and brings to their spot at Carlisle. They look really good. This is the link that Paul posted.
Regards,
Alan
Old Nov 1, 2008 | 04:38 PM
Paul L's Avatar
Paul L
Originally Posted by Alan 71
Hi GGHG,
Regards,
Alan
Apparently they have the original GM jigs/tooling.
Old Nov 1, 2008 | 04:46 PM
78Vette-SA's Avatar
78Vette-SA
You could buy a good used frame for a couple thousand and transfer all your parts over. Figure another 2 to rebuild your trailing arms, brakes, bushings, etc. etc.
For about 10k, you can get a good tube frame with C4 susension, rack and pinion steering, better brakes, and coilovers all around. Requires some body mods to make it work as opposed to a replacement original which of course does not.
Just depends on your budget and what your goal is with the car.
SRIII Tube Frame
Old Nov 1, 2008 | 04:47 PM
Daves76's Avatar
Daves76
http://www.colliertechnologies.com/
Old Nov 1, 2008 | 10:14 PM
Michelp's Avatar
Michelp
I know theres a company in Niagara falls Ont. that makes some replacement frames. Cant remember the place but I delivered a load next door couples of weeks ago and they were fabricating some.
i checked the map but not sure if Collier's the one I'm talking about.
Ok I found them and it's Collier. The name I had was Davert and the adress is the same.
Old Nov 1, 2008 | 10:21 PM
chris75stingray's Avatar
chris75stingray
no reason to buy new when you can get a cheaper used one.
Old Nov 1, 2008 | 10:44 PM
Michelp's Avatar
Michelp
Depends if you want to make it better like 78vette did.
Old Nov 2, 2008 | 04:21 PM
markdtn's Avatar
markdtn
Unless it's an original car I would take this opportunity to change to later model parts with a frame from Steet Shop or similar. LS power, C4 or C5 suspension (and steering and brakes), etc.
Old Nov 2, 2008 | 07:18 PM
72LS1Vette's Avatar
72LS1Vette
He has a 69 and used frames for chrome bumper cars that are in good condition are getting much harder to find and more expensive. The price difference is shrinking between used frames and repro frames for chrome bumper cars, and if you are not doing a NCRS restoration the repro frames offer options that make mods much easier. For example, if you want to put a C4 suspension or a LS motor in the car some of the repro frame companies can provide a frame with all of the mods and brackets that you will need. Saves a lot of time and head-scratching figuring out how to make things fit.
Rick B.
To C3 New Frame
