Quick carpet install question
Old Nov 17, 2008 | 12:19 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Default Quick carpet install question
Quick question about the section of carpet that covers the rear wheel wells. Above the wheel well is a drain tube on each side. Do you cut a hole for the tube or would a slit work better.
Advice and/or photos would be appreciated.
Thanks!
Old Nov 17, 2008 | 05:22 PM
Alan 71's Avatar
Alan 71
Hi 73/454,
On my 71 I cut a slit down from the top edge of the carpet to the top of the drain tube. I then cut a circle out of the carpet for the tube to pass through. I found if you just use a slit, the pressure of the carpet collapses the drain tube.
Regards,
Alan
Old Nov 17, 2008 | 07:17 PM
1996Z15's Avatar
1996Z15
I did the same thing for my '69; cut the slit above the tube and cut a hole for the tube to go through.
Old Nov 17, 2008 | 11:44 PM
73, Dark Blue 454
Thanks Alan and 1996Z15. Slit it is.
Just curious,..how'd the factory do it?
Old Nov 18, 2008 | 04:44 PM
Alan 71's Avatar
Alan 71
Hi 73,
On my 71 there was a slit from the top and quite a nicely cut round hole.
Regards,
Alan
To Quick carpet install question
