M-22 or ???: Trans.selection help
Old Nov 26, 2008 | 06:52 PM
  #61
632C2's Avatar
632C2
Originally Posted by Guru_4_hire
Jim uses the softlok and that might fit the bill. Probably your cheapest option.
The guy at titanspeed is really cool if you want to call them, its like calling dewitts, your probably going to talk to the owner if you call. I really enjoyed my shopping experience when I bought my oil pump.
They are just really expensive.
I am going to have to get in touch with Jim to see what he thinks. I will also talk to George at Autogear for a little more information. Thanks again!
Originally Posted by howarsc
good choice.
If it turns out not to be a good choice, I can always put the trans in the '69 T-Top I'm restoring -- provided the trans is still in one piece!
Steve
Old Nov 26, 2008 | 07:08 PM
  #62
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
So, is that AG M22 going to have a "close" or "wide" ratio gearset (not that the latter is really all that wide)?
Old Nov 26, 2008 | 07:14 PM
  #63
632C2's Avatar
632C2
Based on my conversation with George at Autogear, the close ratio is the strongest so that is what I am getting.
Steve
Old Nov 26, 2008 | 07:45 PM
  #64
howarsc's Avatar
howarsc
You will be moving through them fast but you can use 1st to 4th when cruising through light traffic.
Old Nov 27, 2008 | 03:18 PM
  #65
632C2's Avatar
632C2
I'm not sure I have enough torque for that.
Steve
Old Nov 28, 2008 | 01:16 AM
  #66
gkull's Avatar
gkull
Originally Posted by 632C2
Thanks, George. I was told the Tex Racing T101 was another non-synchro trans. Do you know any of your road racing buddies that are running Autogear M-22's? What trans did you have prior to the TKO?
Steve
Steve, I will ask the boss about M-22's most of the cars in that class run the super t10's with straight cut gears like an M-22. I was looking at one the other day on bench and it was setup with 2.20, 1.64, 1.36, 1.00
Prior to manual I had that 850 hp art carr 700r4. It was very reliable with my lower hp 427 motown. Auto trannies are power suckers because of the pumps and they have traction problems
Old Dec 5, 2008 | 12:23 PM
  #67
632C2's Avatar
632C2
Originally Posted by gkull
Steve, I got the answer on the M-22:
It is a myth that they were good high HP trannys. The problem is the front of the case. The front input shaft comes into the case. Directly below it is the gear cluster shaft. The case is prone to cracking between the two shafts. the Texas Racing trannys use the same size case for the T101A, but they machine out a larger hole for the lower shaft ball bearings and increased the thickness of the case. which makes it much stronger.
My boss said that they used to break the old M-22's once small blocks started exceeding 500 hp
George, I appreciate the follow up. I am hoping that the Super Case on the Autogear M-22 I purchased will be able to withstand any of my abuse.
I have received everything and will be installing the trans this weekend. With any luck, by Sunday I will be able to spend some time breaking it in on the DynoJet before I make a few runs!
Steve
Old Dec 5, 2008 | 04:47 PM
  #68
gkull's Avatar
gkull
Steve
About the only data I could find on the autogear m-22 is that it has a stronger case like the Texas racing. I found that it has a 600 foot pound rating. Is that the numbers you were told? That would be the same as a TKO 600
by chance do you have it rapped up in a tranny flak jacket?
I have a blow proof bell housing and a drive line hoop.
Old Dec 5, 2008 | 05:24 PM
  #69
TheSkunkWorks
...by chance do you have it rapped up in a tranny flak jacket?
Good question/point. With the kind of horsepower you have IMHO it would be wise to run with these safety devices, whether any particular strip's "tech" inspection requires them or not.
Old Dec 5, 2008 | 07:09 PM
  #70
632C2's Avatar
632C2
I do have a scattershield and a driveshaft safety loop but do not have any kind of tranny protection.
As far as the strength of the Autogear M-22, George at Autogear was able to convince me that his M-22 is the strongest synchro-type trans currently available. I'm sure that are many people that would argue this point but I am willing to give it a try.
Hey, what's the worst thing that could happen?
Steve
Old Dec 5, 2008 | 11:24 PM
  #71
gkull's Avatar
gkull
Steve
You are kind of right I had a catastrophic failure of a TKO 500 years ago (not in my Vette) and it just left gears and the bottom of the case for 1/2 mile
Old Dec 6, 2008 | 10:47 AM
  #72
63mako's Avatar
63mako
St. Jude Donor '08-'09
One other thing. Torque ratings are actually what the trans is capable of handling if subjected to that amount of torque continuously for 24 hrs. Actual torque that the trans can handle would be much more than the rating. As I said before My buddy Dave Testin ran one in a street legal 57 Chevy with a 540 W/3 stages of nitrous. 1100 HP. High RPM laonchs W/ slicks and powershifting every week at the Dragstip for 3 years with no issues. Shock when shifting is what will kill any manual and powershifting 1100 HP in a heavy car with slicks on a prepped track is a pretty good test.
Old Dec 6, 2008 | 12:13 PM
  #73
632C2's Avatar
632C2
You hit the nail on the head!
Steve
