Diagnosing Possessed Electrical System
Old Dec 17, 2008 | 02:28 PM
MrGoFaster's Avatar
MrGoFaster
Default Diagnosing Possessed Electrical System
If you've been keeping up with the video progress on this car you know I'm building it with your help from the internet & you know all to well that the way this project has been going from day 1 is "Fix 1 thing & 2 more break" so I wont beat around the bush here, I've eliminated 1 chunk of problems & now have a chunk of new problems times 2 on my hands & my electrical system has major problems.
Recently, to eliminate a big chunk of the problems I pulled all my center gauges & replaced them with aftermarket gauges(don't hate me). It did help because I now have a few gauges (oil pressure & volt meter) that work but the problems are wide spread & erratic, not just gauge related.
This erratic behavior; works one day doesn't the next, does something but nothing remotely coherent etc., has to have a logical solution but it is beyond my current electrical diagnosis capability & thats where I need your, the brilliant & patient members of Corvette Forums, help again.
I own a little volt meter but very inexperienced with using & understanding it. The car is not blowing fuses. I do have detailed wiring diagrams that I can refer to. (happy to E-mail them to you as well they are for a 1979)
Ask me questions, tell me to check specifics & I'll tell you what says what & what does what when I make changes. I am very poor when it comes to troubleshooting & diagnoses. So I must stress "specifics". Like many threads, this thread will be a crash coarse for me but I do learn quickly.
I wish to thank you ahead of time for posting & reading. I know this thread has potential to get lengthy quickly.
Here is the latest video link that shows & describes the majority of the problems. (Yes, I do have too much time on my hands).
Corvette Video 21
http://videos.streetfire.net/video/C...tem_205854.htm
Old Dec 17, 2008 | 02:51 PM
wombvette's Avatar
wombvette
My advice is to pay up your insurance, turn the key on and walk away.
Old Dec 17, 2008 | 03:28 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Have you checked the dash harness ground?
Old Dec 17, 2008 | 03:36 PM
...Roger...'s Avatar
...Roger...
Since you say your not experienced with a voltmeter I would suggest you go to the auto parts store or Harbour Freight and buy a standard 12v test light ($5-$8).You are going to be looking for power on each circuit you are testing,the voltmeter is TOO sensitive for what you are doing and can show you 12 volts even on the grounding side.I can also explain to you how you can reverse the test light when you are looking for available grounds.
Old Dec 17, 2008 | 04:03 PM
jnb5101's Avatar
jnb5101
your headlight situation may be a vaccum leak on the close side of the actuator. when you installed the new gauges, you may have disconnected a ground wire. remove the battery ground wire from the chassis point and freshen the contact. pull a kick panel and run an extra ground from the metal of the lower birdcage to the frame. make sure the large ground lug that attaches to the bellhouse bolt near the starter is there and making good contact.
btw nice video, speilberg!
Old Dec 17, 2008 | 04:40 PM
7T1vette's Avatar
7T1vette
...might have been able to help with the stock gauges. I don't know anything about your aftermarket stuff.... Sorry.
Old Dec 17, 2008 | 06:23 PM
Droshki's Avatar
Droshki
Old Dec 19, 2008 | 09:47 AM
MrGoFaster's Avatar
MrGoFaster
No but I noticed on this new picture diagram I got that there is a harness ground to the left of the speedo. Doesn't actually show what it goes to, I assume there is a piece of metal in the dash. I'll tear into it & find it & check it out here pretty soon.
Old Dec 19, 2008 | 09:50 AM
MrGoFaster's Avatar
MrGoFaster
Thats not a bad idea. I'll pick one up. Thanks!
Old Dec 19, 2008 | 01:08 PM
MrGoFaster's Avatar
MrGoFaster
By chance, I ran across this at a yard sale today for $2 & figured it was worth a shot. Are any of these testing tools what I needed to get? I'm pretty sure the one on the right will tell me if something has power because it has a light but I have no clue what the rest of them do.
Old Dec 19, 2008 | 01:36 PM
MrGoFaster's Avatar
MrGoFaster
Originally Posted by jnb5101
nice video, Spielberg!
Spielberg? Hardly! After that episode I fired my car as an actor for artistic differences.
I wanted the radio to come on & play you keep a knockin, it stopped coming on so I had to do it without showing the radio. I wanted the seat to adjust to do the squished against the steering wheel scene, it didn't move. I wanted it to crash through a gas station & have it burning on fire chasing me down the road but it wouldn't run long enough to drive down the street to the gas station to do it etc etc.
Anyway, I had several things I was gonna do with that episode but like I said, I had a lot of artistic differences going on between me & the car so thats all I was actually able to get on film.
Old Dec 19, 2008 | 01:54 PM
MrGoFaster's Avatar
MrGoFaster
Thats not the first time thats been suggested & it does sound better every time I hear it.
However, I've never driven this car so I don't have any insurance on it.
For now, I'll just keep unhooking the battery before I turn my back on it.
Old Dec 19, 2008 | 02:13 PM
TERRY CLARK's Avatar
TERRY CLARK
GO FAST,....You need to bite the bullet and tow or have it towed to a good mechanic ! They will have it runnin' in a day. just my $.02
Old Dec 19, 2008 | 02:36 PM
MrGoFaster's Avatar
MrGoFaster
True, but then I wouldn't learn anything. My being so hard headed in wanting to do it myself does have a reason behind it. I want to rebuild a car myself for the experience. Taking it to a garage will get it fixed but I would only learn how to pay a bill.
Old Dec 19, 2008 | 03:31 PM
SharkBit's Avatar
SharkBit
I can come check your car out on one of my off days. Cant guarantee anything, but I can run a test light and voltmeter, and the corvette wiring isnt too complex.
Just let me know.
Old Dec 19, 2008 | 04:46 PM
dave_roads's Avatar
dave_roads
in looking at your picture
you have all the grounds tied together including the fuel guage ground.
and reading the instructions at http://earchitect.50megs.com/corvette/gauge.htm
it says several times to reuse the original ground for the fuel guage.
Old Dec 19, 2008 | 04:55 PM
OMF's Avatar
OMF
In regards to your yard sale find, the one on the right is for your 110v plug in recepticle. I think the one you need to use is second from the right. The one on the left looks interesting as well........any instructions with this set???
To Diagnosing Possessed Electrical System
Old Dec 19, 2008 | 05:27 PM
TERRY CLARK
I heard that, but you could have the mechanic tell you what's up and what he did to fix the problem. It's always a last resort to take it to a mechanic ( hate to dish out money for somebody to work on any of my cars )......Do you want to drive it or just wait around and hope somebody tells you how to fix it ? I feel your pain man !
Old Dec 19, 2008 | 06:39 PM
MrGoFaster's Avatar
MrGoFaster
Just let me know.
I can always rearrange my schedule for when you have free time. Just let me know what kind of beer you like & I'll have it on ice! I'm PMing my address for mapquest or GPS use.
Old Dec 19, 2008 | 07:30 PM
SharkBit's Avatar
SharkBit
Got PM
Do you have an assembly manual? What kind of wiring diagram do you have? I have a 79 Also so we can reference off of it if needed. Its tore apart so all the wires are easy to access.
Ill PM you my schedule.
