Birdcage
Old Jan 11, 2009 | 08:22 PM
shank0668's Avatar
shank0668
Default Birdcage
What is the birdcage?
Old Jan 11, 2009 | 08:32 PM
L79racer's Avatar
L79racer
Here it is. If it was a mid year coup it would go over and down the back of the door.
Old Jan 11, 2009 | 09:06 PM
wombvette's Avatar
wombvette
Keeps the Bird in.
Old Jan 12, 2009 | 01:37 PM
Belgian1979vette's Avatar
Belgian1979vette
Seen the number of questions around here about birdcage repairs, I keep wondering why nobody has taken the effort to reproduce proper parts for the birdcages of C2-3 vettes.
Old Jan 12, 2009 | 03:20 PM
7T1vette's Avatar
7T1vette
How many folks remove everything off in order to do a complete repair? Very few... so, there's no money in it for the suppliers. Those that can do that kind of repair just fix them by welding in new material.
Old Jan 12, 2009 | 05:07 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Actually you do can get few re-production parts of the bird cage, like the windshield corners and sides/upper bars.
Old Jan 12, 2009 | 08:38 PM
DZRick's Avatar
DZRick
And some other parts.
Old Jan 12, 2009 | 10:15 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
http://forums.corvetteforum.com/c3-g...-pictures.html
Old Jan 14, 2009 | 10:38 AM
BB72's Avatar
BB72
Default here
http://www.jschroeder.com/lg/birdcage_2.jpg
Old Jan 14, 2009 | 11:57 AM
71coupe454's Avatar
71coupe454
where do you check for damage/rust on the birdcage on a car thats not all tore apart. i can see my vin number is pretty rusty, what should i remove and where should i look? its a 71 coupe. is there any possible rust thats repairable with out major disassembly?
Old Jan 14, 2009 | 12:17 PM
Tom's 79's Avatar
Tom's 79
Default Birdcage Rust - Where to Look
There are a few places you can look without having to tear the car apart. Go inside the vehicle and remove the trim around the inside of the windshield. Bad rust will be obvious. If not obvious, take an awl and try to push through the sheet metal to see if it is weak from rusting from the inside. Check all the way around the windshield.
Another area is behind the kick panels. These are the panels down by your feet on the side walls. Remove them and with a light and mirror look up and down the framework behind the kick panels.
There may be other areas not easily accessible that can be rusted but this will give you a clue as to overall condition.
Old Jan 14, 2009 | 01:41 PM
Belgian1979vette
Seen the construction of the cage, i doubt that the spotrepairs will be longlasting.
To Birdcage
