How to paint this (pics)
Old Feb 1, 2009 | 09:15 AM
kiretunk's Avatar
kiretunk
Default How to paint this (pics)
Hello
Anyone have an idea of how to paint these, and the letters still be blank?
I was thinking of painting everything, and then use a sharp knife to scrape paint of the letters. But maybe anyone have a better idea?
Thx
Old Feb 1, 2009 | 09:39 AM
jnb5101's Avatar
jnb5101
remove all the old paint and clean to remove all traces of contaniments, paint with self etching primer , wait about 5 minutes, and then the cover coat. while the paint is still tacky, use a sliver of wood (as a tooth pick) and rub the paint off parts you want.
Old Feb 1, 2009 | 10:08 AM
Droptop-Rob's Avatar
Droptop-Rob
I do a similar technique, I just wait a tad longer so its not tacky and use an xacto knife.
Rob
Old Feb 1, 2009 | 10:14 AM
Alan 71's Avatar
Alan 71
If you follow Rob's suggestion it helps to use the blade after the paint has 'flashed' but is still a little soft. This way the blade is able to cut a very sharp edge on the paint. This system really works well on all the dash and console trim pieces that are black with chrome exposed.
Regards,
Alan
Old Feb 1, 2009 | 10:45 AM
kiretunk's Avatar
kiretunk
Thanks for the help.
I will try one of these techniques.
Old Feb 1, 2009 | 02:08 PM
7T1vette's Avatar
7T1vette
You will get the best results by removing the metal parts from the door panel and painting them separately. But, you can get good results by just masking them off from the door panel while they are still attached.
To How to paint this (pics)
