My Autofab 4 link solid axle install
Old Mar 26, 2009 | 08:14 PM
  #61
bluzman2004's Avatar
bluzman2004
I don't deal with money at all!! I just design the stuff. I think they were talking about a street price of $1600 complete ready to bolt on and start up. Just pull off your carb, set it on, and connect it up.
Old Mar 26, 2009 | 08:19 PM
  #62
bluzman2004
Noway! A single won't handle your motor! Damn, my motor feels inadequet for some reason.
Old Mar 26, 2009 | 08:48 PM
  #63
pef427's Avatar
pef427
I haven't done my homework on these but does anyone make one for a 4500 base? Does that $1600 price include the intake?
-P
Old Mar 27, 2009 | 08:05 AM
  #64
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Yo P.....
"What you need to do is......."
Let's get a short tunnel ram and 2 throttle bodies...and dry EFI like Doug F. uses. Style points count!
Take care of *my* carb!
JIM
Old Mar 27, 2009 | 09:26 AM
  #65
pef427's Avatar
pef427
Originally Posted by 427Hotrod
Yo P.....
JIM
My 1250 is too "blingy" for your 540. I think I have plenty of hood clearance now for something like this. You really are "The Great Temptor"!
-P
Old Mar 27, 2009 | 12:53 PM
  #66
bluzman2004
These unit use your current manifold.
Old Mar 27, 2009 | 04:26 PM
  #67
pef427's Avatar
pef427
With the tall Dart intake I have, which is for a 4500 carb, it wouldn't work. And just one won't feed the HP. Will my Aeromotive 1000 be sufficient to feed this EFI?
Old Mar 27, 2009 | 11:17 PM
  #68
JoeC427's Avatar
JoeC427
Yep, you are right. I didn't think about that. I guess you just have to live with the wheel wells not lining up perfect! Of course a 1/2" shouldn't be very noticable over all. Thanks for the idea!
Off subject, but check this out. The product I just finished designing at work won an award already!!!
http://www.fuelairspark.com/WhatsNew...nshrraward.pdf
Will you offer that EFI System for a 4500 flange?
Old Apr 1, 2009 | 06:40 PM
  #69
dp9's Avatar
dp9
I hate to bring you guys off the subject of that killer EFI setup, but...
have you thought about the break setup your going to use? I hear a good number of people on other boards going with ford explorer setups. I'm looking at a speedway kit (item # 91031902). I just ordered my autofab 4-link kit today, and Josh wanted to know what breaks I would be using so he could have strange build the axles to fit that setup.
also, I may have missed it, but were you including the rotor when measuring for the wheel placement/axle length?
-Dan
Old Apr 1, 2009 | 07:06 PM
  #70
L79racer's Avatar
L79racer
I'm thinking about this kit for chevy rears.
http://cgi.ebay.com/ebaymotors/ws/eB...m=330308771579
Old Apr 1, 2009 | 08:34 PM
  #71
pef427's Avatar
pef427
-Dan
When I ordered the Strange 35 Spline axles I also bought the rear disc kit with intergrated parking brake kit. I plan to connect it to my existing handle. I haven't crossed this bridge yet so it may get a little tricky. I was gonna get the 40 spline axles from Strange but they won't work with a Detroit Locker, just spools.
-Patrick
Old Apr 2, 2009 | 09:15 AM
  #72
bluzman2004
I'm going with the kit my circle track friends all use. You can get it at a couple of different places. Speedwaymotors.com part number #91031932. JR Performance has one too. The rotor hat is .09" thick at the axle mounting point. You have to subtract this from both sides of your axle/rear overall measurement.
I gave my rear end to the guy narrowing it for me. He has the correct jig, so he can do a better job that I can. He is going install the 4 link brackets, easy access fill/drain ports, the new billet housing ends, and narrow the rear. He said $250 to do everything. I will get the Moser axles, bearings, and the billet housing ends. Should be ready by the 13th or 14th.
Now I just need to get a posi unit for my carrier and the brake kit ordered and it will be ready to go in!
Old Apr 8, 2009 | 06:00 PM
  #73
pef427's Avatar
pef427
Keep us updated! LOL.
Old Apr 8, 2009 | 06:46 PM
  #74
bluzman2004
I got my brake kit in today. I ordered them from Speedway Motors. The whole kit was $249.00. My differential is supposed to be done by Monday, so then all I need to do is setup the brakes and weld the brackets on. Here is a couple of shots of the brake kit. Came with rotors, rotor hats, rotor hat bolts, caliper mounting brackets, calipers, caliper bolts, and brake pads. Everything you need.
Old May 9, 2009 | 05:02 PM
  #75
bluzman2004
Well, I had a setback. Work started to pick up and I had to do some traveling and haven't touched the car for a while. I got my rear back from being narrowed and I got all of my parts in. I mocked it up in the car with the 4 link bars and got everything where it needs to be. I pulled it all back out and threw some paint on it this weekend. I still need to put my posi unit into the carrier (hopefully this week) and put it all back in. I checked and my driveshaft will work and it looks like the U-joints are even the same size. Here are some pics the rear after I welded the brake caliper brackets and braces in. I installed a drain and fill fitting so it will be easy to swap center sections if I decide to build one up with a spool.
Old May 9, 2009 | 06:56 PM
  #76
L79racer's Avatar
L79racer
looks good. I ordered my 12 bolt and 4 link kit last week. Cant wait to get it in.
Old May 9, 2009 | 07:47 PM
  #77
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I wondered what had happened, but that's not exactly all bad news. From what we're seeing, I believe there may be a sizable wave of business about to come ashore in our sector too. Now, get that thing together so we can finally see how it runs, K?
Charlie
To My Autofab 4 link solid axle install
Old May 9, 2009 | 09:31 PM
  #78
bluzman2004
Yes sir!
I am going to see if my friend can help me install the Track Loc into my center section this week and other than that seeing what brake line adaptors and line I need, I'm ready. I think I'm going to go with a kit I saw with small AN adaptors and a steel braded line for each side. I installed the axles and tire/wheel combo and they really fit well. Right where I measured them to be.
Old May 16, 2009 | 07:43 PM
  #79
58impala's Avatar
58impala
Default Lateral movement.
Apologies if I've missed it, but how is the 9" braced for lateral movement? Is there a panhard rod?
Old May 16, 2009 | 07:47 PM
  #80
58impala's Avatar
58impala
Originally Posted by TheSkunkWorks
Tho I myself can attest first hand that the stock Corvette 10-bolt IRS setup will eventually surrender given enough power and sufficient bite, even w/o slicks, the C2/C3 IRS can be beefed up to handle drag racing launches with engines having well over 1000 HP, but it ain't cheap. Fortunately, they're somewhat modular so you don't necessarily have to go all out to prepare them for lesser punishment. The OP simply chose a different route than others of us have taken.
TSW
What mods would be needed to cope with 600 hp if retaining the standard setup? Thanks
