Fan Clutch Testing
Old Feb 12, 2009 | 06:57 AM
NMT1957's Avatar
NMT1957
Default Fan Clutch Testing
Is there a way to test a fan clutch before it goes back on the engine? Mine feels fine when spun by hand, slight resistance, seems tight.
Old Feb 12, 2009 | 08:05 AM
Young69Owner's Avatar
Young69Owner
I've been told to mount the clutch on something and attach the fan normally to the clutch. Spin it by hand and if it goes more than two rotations, now is a good time to replace it. These things last a LONG time.
Old Feb 12, 2009 | 09:15 AM
BKarol's Avatar
BKarol
I always thought the 2 spins was correct but just looked in my 78 Chassis Service Manual and it states
"If the fan and clutch assembly free-wheels with no drag (revolves over 5 times when spun by hand) the clutch should be replaced.
It does make a note: testing a fan clutch by holding the small hub with one hand and rotating the aluminum housing clockwise/couterclockwise should not be considered a test by which replacement is determined.
Old Feb 12, 2009 | 09:38 AM
wfo76's Avatar
wfo76
Gotta heat it up to full operating temperature to test it so probably best done on the car after driving.
When you shut the engine off when hot the fan should stop almost immediately and you should
feel a definite resistance when turning by hand, if not it is bad and should be replaced.
If the clutch is original, it is almost surely gone.
Old Feb 12, 2009 | 11:55 AM
7T1vette's Avatar
7T1vette
Yes. That test is to be performed when the fan temp is beyond the point where the clutch engages. So, the engine is operated to reach normal temps (city driving would do it), then stop the car, pop the hood, turn off the ignition and count the fan revs after the engine has shut down. It should only be 1-2 revs (if the clutch is engaged).
Old Feb 12, 2009 | 04:48 PM
Alan 71's Avatar
Alan 71
Hi NMT1957,
If you decide you need a rebuild, there are instructions around (NCRS RESTORER article) on how to do it yourself. The clutch usually needs more 'fluid', and people use the silicone lubricant that R/C cars use. (Hobby Store)
Enjoying your self?
Regards,
Alan
Old Feb 12, 2009 | 06:23 PM
NMT1957's Avatar
NMT1957
Alan, Thanks for the info. I didnt even know they had fluid in them...imagine that. My fan clutch seems pretty tight, but I didnt want to wait for the engine start to test it. Im going to look at the NCRS site and get some details. And yes Alan im enjoying every minute of this restoration. It seems to get more interesting as it goes. I will probably spend another 3 hours tonight cleaning and sorting bolts in my quest for all originals. I would like to have all bolts prepped and ready before starting the chassis assembly.
Ned
Old Feb 12, 2009 | 08:44 PM
Sayfoo's Avatar
Sayfoo
Actually, there are 2 types. Some are therostatically controlled--silicone grease acts as a clutch and tightens up as it gets warm, and some are just speed controlled. More or less slip at high rpm, as probably not needed when the car is moving and won' rob hp at higher rpm's.
So, the testing techniques are different. As said above the thermostatically controlled need to get hot to test.
You can ususally tell the difference in that the heat controlled type usually have a thermostat bimetal coiled spring located on the housing around the shaft.
Old Feb 12, 2009 | 10:41 PM
DJordan442's Avatar
DJordan442
Ned,
let me know what you find out about rebuildingthanks, Dan
Old Feb 12, 2009 | 10:50 PM
Reggie Dunlop's Avatar
Reggie Dunlop
Karol is correct. All GM service manuals from the late 60s and 70s list the same test proceedure. The next test is performed with the engine at operating temp. With the engine idling, shut it off and observe the fan. If it makes more than 2 revolutions it must be replaced.
Old Feb 12, 2009 | 11:49 PM
NMT1957's Avatar
NMT1957
So they would have to be on the car for either test Im assuming. Mine does have the bimetal coiled spring in the front. Like I said it feels tight just turning the clutch by hand with it off the car.
Old Feb 13, 2009 | 08:35 AM
Alan 71's Avatar
Alan 71
Hi Ned,
The tech article I was referring to is in the Spring 2007 RESTORER.
It is however for the Switzer clutch, the one with the bi-metallic bar, not the bi-metallic coil, which is an Eaton clutch.
Good Luck!
Regards,
Alan
Old Feb 14, 2009 | 07:27 AM
NMT1957's Avatar
NMT1957
Alan, Im going to look into the Eaton clutch and see if there is a rebuild I can do myself. Id rather rebuild it now than have to change it later after the engine is done and body on, not that that is going to happen any time soon but just trying to stay ahead of it.
Thanks, Ned
Old Feb 14, 2009 | 10:37 AM
tommyleea's Avatar
tommyleea
Not sure how much a new fan clutch would cost, but considering your questions, you won't be able to sleep at night if you reinstall that one as is.
TommyJ
Old Feb 14, 2009 | 04:01 PM
NMT1957's Avatar
NMT1957
Yes, that could be true. I just saw that Paragon has a rebuild service for your fan clutch. ill probably send it to them.
Old Feb 14, 2009 | 07:09 PM
DJordan442's Avatar
DJordan442
Ned,
Paragon has discontinued their rebuild service - just checked a few weeks ago. Let me know if you find that Eaton Clutch rebuilds. I will check with Jerry MacNeish also. thanks
To Fan Clutch Testing
