I have noticed that happens a lot here. Someone asks for first hand experience on brand x and brand a-w gets talked about.
That is just human nature. Brand name is always better and is in most cases. I cheap out a lot on things and end up paying for it in the end.
In this case, the thread starter should install the heads he bought and let us know how they work out. Not second guess his instinct like he is doing know.
I received my ProComp cylinder heads this afternoon. I now have hands on and can judge for my self what all this is about. I bought the pair from GR8HOTRODS.COM on eBay to my full satisfaction. Swift and responsive seller, no wonder they have achieved 100% feedback. The pair is ProComp PC3003S, 210cc with 64cc chambers and straight plugs. They were a little “bigger” than first planned, but that’s OK …no worries!…. At a first glance I can state that the cast and machining is of very high quality and there won’t be much porting needed. I am looking forward to install these lovely cylinder heads on my 383.
Lucky you! Go and inspect the ProComps for your self. That is much better than being told off by self appointed experts, which never have had hands on these cylinder heads in their life. I suspect the ProComps to be OK for my use, possible for you as well....
Good luck to you as well!
Arne
I had a set of them, I looked didn't like what I saw and filled them with Argentinian S.Stl valves and sold them off to the GREATER FOOL on Ebay. We were offered a dealership for them when they first appeared 4-5 years ago and if we bought $10K or more of inventory, the heads were under $420 a set, I guess we should have JUMPED on that deal and become one of Ebays biggest sellers but, we take PRIDE in what we do in our machine shop. I wouldn't travel over to Germany and do a top end check on the Autobahn with them if I were you
These heads have been "hammered" by many who never had the opportunity to build on ANY platform whatsoever!
We've experimented with a number of sets of these head!
I can give you all this, on a really "base" 383 SB, Comp retro-hyd cam, and "100 year old (or so)" Torker intake, you will get 450 HP and 440 Ft.Lbs. Torque with a "bolt-together" deal!
I have numerous dyno sheets here from these builds! Most are using a 10:1 C.R. With some porting and some add'l HP chasing, you can get up to the "500" number quite easily! A "solid-roller" platform by itself would add some 30/50, depending on the peripherals including a decent intake, possibly with an "HVH" series??
Thanks, Gary in N.Y.
P.S. Those numbers above are using the PC3001's, these are the angle-plug series, and NO porting whatsoever, not even a "slight" gasket match, and are now "getting the job done" in quite a few "rides"!
Thank you very much for your informative posting Gary! I think this is to be a good build from what I have seen so far. I'am very impress by the quality of these heads... the cast is perfect. I am planning next week to order another identical pair for my 350 build. I just have to find out what camshaft to use first. I think I need much higher lift this time.
Glad you got them and are satisfied with them. Would you have any close up pics of the intake runner, exhaust port and combustion chamber ?
Both intake and exhaust runners are good for direct bolt on. So are combustion chambers. The cast inside is quite even and will not require much work to be perfect. We'll see later if I am to publish my findings. Right now I'll spend more time in workshop finishing up my two builds and let you guys do the posting here on CF.
rgds
Arne
I agree w/ Motorhead & 63 Mako. I also researched these Pro Comps and only heard negative comments about them. Also, it sounds like you only want to hear good things about your cheap heads? One last thought, buy American.
If your research is based on hearing comments, and that's how you do things over there ....no wonder you guys got problems .....
Most research is based on hearing comments, just like yours.
You just put more faith in the comments that coincide with what you would like them to be.
You can see where it should be and where it is. Both exhaust ports dump in the center on #4 and #6 so heat is more concentrated in the center than throughout the rest of the head and full coolant flow is the most critical here. Would bet the head warped causing the blown gasket due to inadequate coolant flow between cylinder 4 & 6 as a direct result of poor quality machining. Did you check the head with a straight edge for warpage?
Wow! Good eye. With that overlap between the actual hole and the hole in the gasket, would you say the coolant passage was cut down to about 20% of what it should be? Little wonder that ended badly.
I think some people can be told not to touch the hot stove, and they get it,
other people have to touch the stove anyway and find out firsthand why it's a bad idea....
I don't pretend to be an expert, but I now know enough that 1) playing with vettes gets expensive and 2) trying to cut corners (especially on something this critical) is a really bad idea. There...I said my 2 cents (or euros as the case may be).
just do an internet search, as I did when I saw them a year ago or so... Someone did a direct dyno test on them and they were worse than the stock heads!!
I have 7 words.. "They are junk junk junk junk junk". Was that seven?.... it always seems to boil down to you get what you pay for. I payed more than that just for porting, polishing, and port-matching on my heads....
Sure thing, but have you ever used or inspected these cylinder heads? I am not very much worried about where in the world they have been produced, so please keep this on a technical level and skip promoting other brands. They are selling a lot of these ProComp cylinder heads on eBay, so it must be a reason for this.... would'nt you think? Anyone else please....
rgds
Arne
