yellow liquid leak
Old Mar 8, 2009 | 10:32 AM
vetteman305's Avatar
vetteman305
1st Gear
Default yellow liquid leak
I have a 1982 crossfire injection vette. For the past couple of months the car has been leaking a yellow liquid in the front passenger side. Any idea what it is and how to fix it? Any help would be appreciated.
Old Mar 8, 2009 | 11:39 AM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
Got to be coolant. Check all your hose connections and check the radiator for leaks. These cars get all kinds of gremlins in them during the winter hibernation. Your car is just trying to tell you that it needs some love. Go take it for a ride. haha
Have a nice day! It's going to be about 60 today so I'm taking mine out for a spin just to rid it of the "Winter Gremlins".
Dave
Old Mar 8, 2009 | 11:55 AM
wfo76's Avatar
wfo76
Zerex coolant or maybe could be a/c compressor oil?
Does your a/c work now?
Old Mar 8, 2009 | 12:44 PM
71406's Avatar
71406
Sounds like coolant. Many part stores allow you to borrow tools. If you can borrow a pressure tester, you can connect to your radiator (in place of the radiator cap) and add pressure to the system. This will allow you to inspect the system under pressure. Do it when its cold to make the inspection easier. You may also want to inspect your overflow tank and radiator cap. Is the overflow tank still there and connected? And test the radiator cap. If its weak it may be allowing pressurized coolant to seek out through the overflow tube and drip on the ground. Again a tester allows you to check out they system and the cap.
Old Mar 8, 2009 | 03:00 PM
Attfay Elleybay's Avatar
Attfay Elleybay
is it leaking on the ground or inside on the pass. floor?
Old Mar 8, 2009 | 05:34 PM
supercalvin's Avatar
supercalvin
If its inside the passenger compartment
My bet is a coolant leak in the heater core.
Old Mar 8, 2009 | 06:53 PM
midyearvette's Avatar
midyearvette
bad heater core........
Old Mar 8, 2009 | 07:25 PM
swampblues's Avatar
swampblues
i bet it's ac compressor oil - that stuff is yellow.
Old Mar 8, 2009 | 08:14 PM
Young69Owner's Avatar
Young69Owner
Was it only when you had a passenger..? Sorry, couldn't help it...
Old Mar 8, 2009 | 08:20 PM
7T1vette's Avatar
7T1vette
Is there some bad-a$$, muscle-bound BB that crosses paths with you and your car on a regularl basis? I mean...that might cause some yellow liquid to be dribbled out.... {probably coolant, though..}
To yellow liquid leak
