X pipe crossover installed, what a difference
Old Mar 21, 2009 | 09:39 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
That actually looks like the x-pipe in my Magnaflow system. I bought it a couple months ago, but have yet to install it. When the 5 speed goes in, the pipes will go on. I figure it will be ready to roll after tax season!!!
I look foward to hearing a new clip!!!
Old Mar 21, 2009 | 10:39 AM
Bee Jay's Avatar
Bee Jay
Originally Posted by l88rocket
Take out the H pipe it will sound and run better
Why? Is the H-pipe detrimental in any way? I've never read that anywhere. I'm very happy with how it sounds and runs now.
Bee Jay
Old Mar 21, 2009 | 01:38 PM
mysharkbite's Avatar
mysharkbite
Cruising
Originally Posted by QuicheLorraine
Nahh the optimum crossover pipe location on any vehicle with headers, is 18" behind the collectors. The only thing is, that in a C3 that's hard to do.
I've also heard this from a muffler shop, they said it didn't make sence to put an H-pipe in because you couldn't get it close enough to the headers.
I have the same crossmember from bowties and was thinking about curving the H-pipe under the tranny mount to keep it within 18".
Old Mar 22, 2009 | 01:33 PM
pauldana's Avatar
pauldana
Is anyone worried about the heat generated near the rear-end? heat in the differential oil along with natural friction heat being to high? or the extra heat near the composite spring?
Also you plate says 1979, but your rear looks like an 80+ did you do this change? if so how difficult was it? and how much weight did you save?
Old Mar 22, 2009 | 04:25 PM
emccomas's Avatar
emccomas
I gotta ask. Where is your catalytic converter and how do you get away with not having one in California?
Old Mar 22, 2009 | 05:33 PM
Bee Jay's Avatar
Bee Jay
Check out my batwing mod here:http://forums.corvetteforum.com/c3-t...g-install.html
The X-pipe doesn't generate any more heat than the non-X pipes.
Old Mar 23, 2009 | 02:06 PM
pauldana's Avatar
pauldana
Went to your link and it says "page not found" and i would very much like to see it. just is a lot more pipe there covering the underside of the rear with no breather holes... and what about your composite spring? thx!!! p:-)
Old Mar 23, 2009 | 02:07 PM
pauldana's Avatar
pauldana
Thats a secret many of us have...
Old Mar 27, 2009 | 12:49 AM
Bee Jay's Avatar
Bee Jay
Try the batwing mod link now. It's also in my signature.
Bee Jay
Old Mar 27, 2009 | 07:43 AM
gkull's Avatar
gkull
Yep, Didn't expect much from the X pipe since I already had an H pipe, but I was surprised. Maybe someone can explain why. I would advise anyone with an H pipe and their system is still too loud, try an X pipe before you toss the mufflers. I drove the car to work this morning and I had a conversation with the wife. Tonight I'll try the stereo.
Bee Jay
Your H pipe was: too long, not up close to collectors, and of too small a diameter to work correctly.
But I'm one to talk because my three inch system with 3 1/2 in and out mufflers sets off car alarms driving slow in parking lots
Old May 18, 2009 | 12:19 PM
Bee Jay's Avatar
Bee Jay
I finally have video of the exhaust sound with X pipe. So here you go. Let me know what you think.
Bee Jay
Before X-pipe:
After X-pipe:
Old May 18, 2009 | 07:33 PM
MN-Brent's Avatar
MN-Brent
Unless you have a vid of the drone in the car, its hard to tell. Sounds great to me in both vids actually.
The second vid, with X-pipe, sounds better on the vid, only because the first vid seemed to be clipping the sound (pegged out your mic).
Doesnt sound like you lost anything on acceleration, but if the drone is gone, sounds like success to me!!
Old May 18, 2009 | 08:48 PM
  #33
Bee Jay's Avatar
Bee Jay
Believe me, the drone is gone. Also the noise level is way down, hard to tell in the video. Also the sound is different, more a growl than a rapid fire machine gun.
Old May 18, 2009 | 10:59 PM
  #34
aussiejohn's Avatar
aussiejohn
Default Project for Bee Jay
Bee Jay,
You know what you have to do now. Seeing that you already have an H pipe, you must complete the following experiment for the benefit of all of us here.
STEP #1: Cut the H pipe and fit in an operable exhaust heat riser valve and make sure that there are no leaks.
STEP #2: Get a long piece of vacuum hose and connect one end to a good vacuum source on the engine, feed it into the passenger's compartment, and then loop it and run the other end down to the heat riser valve in the H pipe.
STEP #3: Then, with a passenger holding the hose and a pair of pliers, go for a drive and have the passenger squeeze the hose closed at various engine and road speeds, thereby opening and closing the valve, and therefore, the H pipe. Record the different sounds from both inside and out.
STEP #4: Report your findings here so that we all may learn.
Be prepared to become famous! Let's see - Einstein, Von Braun, Bee Jay! I can see it already.
Regards from Down Under
aussiejohn
11 weeks to go
Old May 18, 2009 | 11:38 PM
  #35
gingerbreadman1977's Avatar
gingerbreadman1977
glad your X-pipe made a difference. i have never heard anyone yet say they were happy with a H-pipe over a X-pipe. i think yours sounds heaps better now .love the video below too..should be more like them on here.
Old May 19, 2009 | 12:59 AM
  #36
Bee Jay's Avatar
Bee Jay
Originally Posted by aussiejohn
Bee Jay,
aussiejohn
11 weeks to go
Hey, I did major in Physics, I have a Physics degree. And I'm an Aerospace Engineer (rocket scientist). Does it pay good money to be famous. I don't remember Einstien or Von Braun being rich. What kind of car did they drive?
Here is another video.
Bee Jay
Old May 19, 2009 | 10:10 AM
  #37
Bee Jay's Avatar
Bee Jay
Here is another clip. This is fun.
Bee Jay
To X pipe crossover installed, what a difference
Old May 19, 2009 | 12:17 PM
  #38
Evershark's Avatar
Evershark
I installed an H pipe exactly 18" behind the header collectors, between the transmission mt and crossover. Used 2" pipe connecting to 2.5" duals. The total installation with Magnaflows was a performance improvement but I still have resonance at 14-1500rpms. Too small an H pipe?? Couldn't fit a larger diam in there.
Old May 19, 2009 | 06:41 PM
  #39
Bee Jay's Avatar
Bee Jay
I was always told to use a cross pipe equal or larger than the primary pipes. Try the x-pipe under the rear end. You'll be glad you did. I can't see your entire system, but you might try a large cross pipe toward the rear end. That is what I was gonna try, but my muffler guy had a C6 x-pipe laying around.
Bee Jay
Old May 21, 2009 | 04:29 PM
  #40
davidarborg's Avatar
davidarborg
Default x-pipe custom exhaust
here's some photos of x-pipe exhausts we have done lately:
3" bigblock
2 1/2" smallblock
Last edited by davidarborg; Feb 24, 2011 at 04:58 AM. Reason: different location pictures
