Anyone Supercharged???
Old May 17, 2009 | 07:54 PM
pws69's Avatar
pws69
Originally Posted by luerja
6-71 for me
And then leurja says "that's not a blower, THIS is a blower!!"
Nice one!!!
Old May 20, 2009 | 06:03 PM
58impala's Avatar
58impala
6-71 for me
Sorry guys, there's no substitute for the real thing!..6-71 for me too
Old May 22, 2009 | 02:03 AM
Z-man's Avatar
Z-man
Originally Posted by nmbr6
Built by my dad
Very nice setup!
Originally Posted by DeltaT
Unless you have a drag-only stup, you need a monster air filter to feed a blown beast, and their rear-fed marine setup only has space for a screen. If you were willing to go around the side like a Cobra setup, then you could have a 4" throttle being fed by a properly-sized filter.
Jim
Mine came from Whipple with both the screen and two perfectly fitting K&N oiled cotton filters. You can rig something up like a Cobra setup, but why bother? A lot of the Vettes and Camaros used the cowl type hood to take advantage of the high pressure area in front of the windshield. With an L88 hood, there's a massive inlet for air at the rear of the hood.
Here's a picture of the air filter on the throttle body. The left has the screen and the right has the K&N.
Originally Posted by Guru_4_hire
They say that their marine rear entry EFI thing wont work on a street car. The technician at whipple was shocked that people are using them on street cars.
Something about the throttle.
I bought the "hot rod" kit from Whipple - it was specifically configured for a street vehicle... They must have noobie techs. Yes - the throttle is on the passenger side, but compared to all the other mods you do when you're putting EFI on a Vette Rod, it's pretty minor. I put a Lokar throttle cable on it and it works great.
I couldn't fit a Whipple under the stock hood because the front of the unit is just a tad too high. I opted for the L88 style hood and have a good 2 inches of clearance now.
It's hard to describe how much fun it is to drive the Vette now with a supercharged engine! Hit the throttle and the seat just slams you from behind...
Here are approximate diminsions from the front. It's probably about the same for a small block. I didn't bother with an intercooler, but I am running EFI to keep the height down.
Old May 22, 2009 | 08:36 AM
SuprJames's Avatar
SuprJames
Originally Posted by 73jst4fun
I saw a Magnuson supercharger on a newer vette 2002 last week when a few guys met from the Forum at a local spot. Everything looked stock as he pulled in, hood tires, etc. The only thing I could tell was the slight high pitch whine...pretty cool and he's about 585hp at the rear wheels. He has the larger model and it stilll looked pretty compact, my thoughts were "so how can I fit that in....Alot of the guys here use ECS to do the work...
I think any of the Maggie's will fit under a L88 hood. Here's mine:
Old Dec 11, 2009 | 01:40 PM
DeltaT's Avatar
DeltaT
CF Community Team
Z-Man,
It's a clean setup but I would argue that those K&N's are restrictive at that size. Do you notice a difference in response with only the screens on? Have you dynoed yet, and if so, did you try a run with screens only as opposed to having the filters on? Maybe the numbers are so good that the restriction doesn
t matter much.
Jim
Old Dec 11, 2009 | 05:10 PM
UHF's Avatar
UHF
All very nice. I will have a whipple sometime this upcoming summer. Got a T-56 going in first. I have debated either whipple or magna, but have not see a magna kit like the whipple hot rod kit. How complete was the whipple kit and what was the final price? What mods did you make to make it fit, cross member notching or what ever?
I have a GM 350 RamJet right now with efi and such, so install wouldn't require too much work with my current EFI, fuel lines, passenger throttle, etc already in place. What fuel controller are you using with the magna or whipple?
Old Dec 11, 2009 | 06:44 PM
auavette's Avatar
auavette
This my 76 with a 496 and a Weiand 8-71 blower.
Steering changed to rack and pinion and a remote powersteering reservoir and monoleaf front spring suspension.
De Witt radiator with 2 electric fans one that starts with the engine and one that kicks in at 185 degrees.
Is for sure a attention grabber where ever i go with it.
Old Dec 23, 2009 | 09:11 PM
UHF's Avatar
UHF
Excuse the ignorance, but where are the injectors on the whipple and magna setups? I just went to Whipple today in Fresno and they do not have a MPI for "non"-LS engines.
Old Dec 23, 2009 | 09:12 PM
UHF's Avatar
UHF
If your whipple or magna are intercooled, where did you put the water box or cooler for the water and the pump?
Old Dec 24, 2009 | 09:16 AM
78Vette-SA's Avatar
78Vette-SA
In my case I used the Maggie Hot-Rod unit which has the Intake set back and the intercooler ports near the front.
The 3/4" hoses coming in right under the red intake bridge hose.
I modified a Coolant Tank with 2 AN fittings welded on and use it for the Intercooler tank and behind it is the overflow tank. In my case it's right behind the passenger side wheelwell. I run DexCool 50/50 in the Intercooler.
You can't see it but the Intercooler pump is down in the right front corner just off to the side of the passenger headlight (under the red towel). I actually ran the return hose through the inner fender and up to the pump.
The air intercooler itself just fit between the Aluminum radiator and the A/C condenser. In this pic you can see it tucked down in there. Wth the Aluminum rad, the A/C going, the Intercooler going, and a Hot summer day, the most the motor ever gets up to is the 195 max then the temp send kicks on both fans. It ussualy averages between 185-190.
Old Dec 26, 2009 | 12:53 PM
Billysvette's Avatar
Billysvette
Heres mine
Old Dec 26, 2009 | 01:49 PM
UHF's Avatar
UHF
Z-man, yours in NOT an LS engine right? I see you're in Co, I'd love to stop buy some time and check out your ride. I'm in the springs myself.
Old Dec 26, 2009 | 01:53 PM
  #33
UHF's Avatar
UHF
MMuumm Weiand, so classssiccc. Very nice.
Old Dec 26, 2009 | 04:18 PM
  #34
Bubs's Avatar
Bubs
Billy, Your vette is one of my favorites! The way it sits and just the scoop sticking out of the hood, beautiful !
Old Dec 26, 2009 | 07:31 PM
  #35
Billysvette
Thank you Bubs
