ground strap question
Old May 26, 2009 | 09:45 PM
early71's Avatar
early71
Default ground strap question
the ground wire from block to starter bolt,is it a single wire or narrow braided wire?I'm not talking about main block to frame cable.It's a '71 s/b 4spd
Old May 27, 2009 | 07:19 AM
Bob Walker's Avatar
Bob Walker
I know nothing about a '71 in particular, but I can't imagine why there would be a ground wire from the block to the starter bolt. After all, the starter bolts straight up to the block, best ground connection you could get.
Old May 27, 2009 | 09:27 AM
Duke94's Avatar
Duke94
Here's my 71' SB. The black ground wire comes out of the engine harness and connects to the starter bolt.
Gary
Old May 27, 2009 | 03:11 PM
7T1vette's Avatar
7T1vette
The ground wire from the starter mounting bolt (on the engine block) to the motor mount bracket is a #2AWG braided wire. You can buy some wire at a hardware store and solder some lugs on it; or you can buy a new ground strap already made up from many of the Corvette after-market parts suppliers [i.e., lectriclimited.com].
Old May 30, 2009 | 05:45 PM
xkeots's Avatar
xkeots
Gary
This is what I did before I saw this, thanks again
Jack
To ground strap question
