Really quick timing question
Old Jun 13, 2009 | 11:49 PM
DaJesterMan's Avatar
DaJesterMan
Default Really quick timing question
Hey guys,
I have a 427 BB and I can't find anywhere what the initial and mech. advance should be set too? I am not running a vaccum advance unit.
See, I told you that was a quick question...
TIA
-ks
Old Jun 14, 2009 | 01:21 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Without knowing a single thing about your combo...the only thing I can suggest is to start with 36* total timing. Might do better with 38*-40*...but that's up to the combo.
Tuning dist for base timing to be around 20-22* and limit it to the 36* total or so will really wake up low speed manners.
JIM
Old Jun 14, 2009 | 10:08 AM
Jeff_Keryk's Avatar
Jeff_Keryk
My stock 68 L36 distributer has 16* mechanical advance (32* @ crankshaft). The initial setting is 4*, so total is 36*. I being it in a little faster; all in by 2800 RPM. It sounds like you have an aftermarket distributer. I would get a timing tape and measure.
Old Jun 14, 2009 | 11:01 AM
Ironcross's Avatar
Ironcross
solid lifter engines normal initial lead is 10 degrees and range from 8-14 according to a Bill Thomas tune up chart.
Old Jun 14, 2009 | 11:23 AM
DaJesterMan
i guess this is a little more complicated than i thought...
i have no information on the heads, cam, or compression ratio. so i guess ball park would be what 427HotRod suggested... 20-22 initial, 14-16 mechanical, all in by 2800
i thought these were reasonable numbers but i wanted to double check...
-ks
Old Jun 14, 2009 | 11:30 AM
...Roger...'s Avatar
...Roger...
You can also go out and drive and bump the timing a little at a time until it just starts to ping and then back it off until it doesnt and then check your timing and see where you are.
Old Jun 14, 2009 | 12:04 PM
DaJesterMan
i have never heard an engine ping before, is it loud? what does it sound like?
Old Jun 14, 2009 | 12:54 PM
7T1vette's Avatar
7T1vette
Like there is a bolt rattling around in one of your cylinders. Not good.... Just set the mechanical advance for 34-36 deg {max, with vacuum advance removed and line plugged} all-in by 3000 rpm. Hook up the vacuum advance system to verify that you get a 'total' advance around 52 deg and test it to verify no pinging under load. If it idles OK, don't even worry about timing at idle; just fine tune the idle mixture and idle speed.
To Really quick timing question
