Distributor sheild question
Old Jul 22, 2009 | 04:34 PM
nutsy's Avatar
nutsy
Default Distributor sheild question
just ordered the dist. shield for my 72 454. i was wondering how it attaches to the motor. it comes with the brackets . do you use the bolts from the intake manifold or do i have to get something else? thanks.
Old Jul 22, 2009 | 04:49 PM
Alan 71's Avatar
Alan 71
Hi N,
You use the intake manifold bolts as you thought. Take a close look and you'll see which bolt needs to be used on each side.
Regards,
Alan
Old Jul 22, 2009 | 04:53 PM
nutsy's Avatar
nutsy
hi ALAN. was hoping to hear that. didnt want to have to pay another shipping charge. thanks, NUTSY.
Old Jul 23, 2009 | 05:32 PM
nutsy's Avatar
nutsy
JUST GOT MY IG. SHIELD. CAN SOMEONE TELL ME WHAT THE SCREW STICKING UO ON THE PASSENGER BRACKET IS FOR? there is no hole for it to go through on the shield. maybe a ground screw?
Old Jul 23, 2009 | 09:54 PM
7T1vette's Avatar
7T1vette
I don't know for certain. My SB '71 manifold has that also. I suspect it was used to assist in moving the engine around in the plant (before assembly to the vehicle)...but I'm just guessing.
Old Jul 23, 2009 | 11:04 PM
72ragtop's Avatar
72ragtop
without seeing exactly what your talking about. I'm going to say it is the threaded piece that the braided wires go to? Should be on both bracket
Old Jul 23, 2009 | 11:15 PM
larryg3's Avatar
larryg3
if you are talling about the screw on the pasenger side of the shield it is for a ground strap. at least it is on my '81
To Distributor sheild question
