Exhaust heat riser valve
Old Jul 28, 2009 | 08:57 AM
Rally68's Avatar
Rally68
Default Exhaust heat riser valve
After re-assembling my exhaust I have a pretty noticeable leak where the heat riser is on the passenger side. I didn't disassemble that joint but was moving the exhaust around a bit, taking it apart and putting it back together. I'm clueless about this part.
What does the valve do?
Does it need lube/maintenance?
I've seen where vendors sell spacers to replace the valve; is this a good or bad idea?
Lastly, will I ruin anything (gasket, etc.) if I try tightening this joint?
Thanks!
Old Jul 28, 2009 | 10:08 AM
7T1vette's Avatar
7T1vette
That valve is meant to [partially] close off the exhaust flow on the right bank to force heated exhaust up into and across the intake manifold for heating the carb choke. That valve has a bi-metallic spring on it which unwinds as it heats, so that it will open the valve completely once the engine is warmed up. To keep the valve from locking up, it needs to be lubed...but it has to be very hi temp lube or graphite product [dry lube]. The shaft is all that needs to be lubed. To test, just move that counterweight up and down to be certain there is freedom of operation. If the heat riser is leaking exhaust, someone didn't install the 'donut' gasket to it.
Old Jul 28, 2009 | 02:30 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
they make a spacer to eliminate the heat riser completely,
I suggest that if you live in a warm climate, with min. cold weather. 69VETT
Old Jul 28, 2009 | 03:33 PM
Alan 71's Avatar
Alan 71
Hi R68,
There's a packing 'donut' and a sheet metal extension 'sleeve' that fit in the connection between the heat riser, and the head pipe. Did they get moved around a little so they're not giving the seal you had before disassembly?
Regards,
Alan
Old Jul 28, 2009 | 06:33 PM
7t3shark's Avatar
7t3shark
You can also easily wire it open. First thing I did after picking up and never had any cold weather driveability problems. Later when had intake manifold off, blocked off the crossover passage to keep carb cooler after engine was warmed up.
Old Jul 29, 2009 | 09:06 AM
Rally68's Avatar
Rally68
Originally Posted by Alan 71
Hi R68,
Regards,
Alan
That's what I'm thinking. I hope it's that simple. I'll get to the bottom of it this weekend.
Until then, I'm disturbing the peace
Old Jul 29, 2009 | 10:05 AM
TimAT's Avatar
TimAT
If you want to lube it, there's a product called "Mouse Milk" Works great in Hi-Temp applications. Used on small turbocharged aircraft to lube the turbo wastegate.
Old Jul 29, 2009 | 10:55 PM
7t3shark's Avatar
7t3shark
Not sure if still available but in late '60s, GM sold a aerosol heat riser lube that worked well.
To Exhaust heat riser valve
