68 vert door panels
Old Sep 12, 2009 | 11:12 PM
base1957's Avatar
base1957
Default 68 vert door panels
Got the panels redone... look nice... now to get them back on.
Is there a way to get them to stay on without using the 4 screws...I can't bring myself to punch the hole in em...
Old Sep 12, 2009 | 11:51 PM
DZRick's Avatar
DZRick
Any chance of getting some pictures?
I plan on using 2 more of these on my panels instead of poking hole through a brand new set.
http://www.ecklers.com/product.asp?p...1&dept_id=1661
Old Sep 13, 2009 | 12:17 AM
base1957's Avatar
base1957
workin on the pics as we speak
how would you get the other two clips to attach to the panel?
Old Sep 13, 2009 | 12:25 AM
base1957's Avatar
base1957
Default door panel pics 68 vert
before:
http://i168.photobucket.com/albums/u...vette68004.jpg
after
http://i168.photobucket.com/albums/u...vette68003.jpg
Old Sep 13, 2009 | 10:27 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
about how much to recover? Did you recover them or hire them done ?
I am considering recovering mine, replacement is exspensive !
thanks, 69VETT
Old Sep 13, 2009 | 10:30 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you don't use the screws they will try to come off the upper support. I don't know of a way.
DZ, that clip slips between the ABS backing (cardboard if original), is there a way to get that in up at the top? (I don't have a panel here to look at).
Willcox
Old Sep 13, 2009 | 10:36 AM
base1957's Avatar
base1957
Package Deal
Rebuilt the seats with ortho foam, tied the springs up, recovered to match the door panels.
1200 for all
I thought it was a good price
Old Sep 13, 2009 | 10:37 AM
base1957's Avatar
base1957
I have in the past used the super industrial velcro and wonder if placed strategically would it not hold.
Old Sep 13, 2009 | 11:32 AM
DZRick's Avatar
DZRick
Willcox
I'm almost positive that I read (AIM?) that the early 68 used 4 retainers instead of poking holes through the upper corners of the panels.
I'll have to take a look at my old panels but the fact that they were used on the bottoms makes me think it shouldn't be difficult to add a couple to the top.
My repos are ABS so mine are going to be easy.
I'll check my AIM along with the old panels and post my findings.
Old Sep 13, 2009 | 12:04 PM
Alan 71's Avatar
Alan 71
Hi,
When installed properly, what is the relationship of the 'vertical fins' on the top of the door frame and the metal channel that's part of the original trim panel whisker mount? Does that 'channel' clip over those fins or not?
The position of those 2 parts affects whether you can see down into the door's guts from the outside.
When I 'clip' the top of the trim panel, it makes a good appearance, but the inner and outer seals are so close and tight its hard to wind the window up and down because of the friction.
I'm using original door trim panels and outer seals.
Regards,
Alan
You can see the first two of the 'fins' sticking up in this picture.
Old Sep 13, 2009 | 12:22 PM
DZRick's Avatar
DZRick
Originally Posted by Alan 71
Hi,
Regards,
Alan
Alan,
The 68 uses a piece that bolts to the door frame that has a whiskers on the window side and a roughly 1/2" strip of rubber on the inside as a filler that covers those "fins".
Old Sep 13, 2009 | 12:34 PM
DZRick's Avatar
DZRick
Willcox
Ok, It was in the instructions that came with my repo panels that says "If your corvette is an early model that utilizes retaining clips in these locations instead of screws". That's where I got the idea of using clips even though mine is a later model.
I looked at my old panels and they have cutouts up top just like the lower retainer cutouts. Even if they didn't it looks like it wouldn't be difficult to add them.
That's the good news! The bad? I need to borrow that heat gun again.
Old Sep 13, 2009 | 01:16 PM
base1957's Avatar
base1957
Default dz
DZ
would you screw the top clips into the panel or is there way to build and glue on a fitting to the back of the panel
Old Sep 13, 2009 | 01:28 PM
DZRick's Avatar
DZRick
DZ
I'd do it just like the bottoms, take a look at how those clips are on your panels at the bottom corners. It should be clear to you what I mean but if not I'll take some more pictures.
Old Sep 13, 2009 | 06:15 PM
base1957's Avatar
base1957
looks like A slit in the panel.
I wonder if there is any adhesive (epoxy perhaps) which would hold a metal clip intact against the back of the original panels. The one would not have to slit the backing.
Old Sep 13, 2009 | 06:21 PM
DZRick's Avatar
DZRick
I think epoxy would work on original panels.
Old Sep 13, 2009 | 06:23 PM
base1957's Avatar
base1957
That may be the route I take. Seems it would be very easy to make some clips, epoxy them down, then drill holes to anchor them to the door
My car is way past original anyway and that would look better than putting holes in em
To 68 vert door panels
