headlight switch vacuum leak
Old Sep 28, 2009 | 12:37 PM
crf311's Avatar
crf311
Default headlight switch vacuum leak
I just got my vacuum hooked up on my light. But I have a vacuum leak in the headlight switch. Put the light on and vacuum leaks out of the switch, Turn off and there is no vacuum leak. So my question is can the leak be fixed or do I need a new switch?
Old Sep 28, 2009 | 01:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You probably need a new switch.
Old Sep 28, 2009 | 02:48 PM
...Roger...'s Avatar
...Roger...
You probably have the 2 hoses reversed,that creates a leak. In this first diagram from Corvette 101 WHICH IS POSTED ALL OVER THE WEB AND STILL IS BEING POSTED the hoses in the red circle show them hooked up BACKWARDS. In the second diagram is the correct way to attach the hoses.
Old Sep 28, 2009 | 02:53 PM
7T1vette's Avatar
7T1vette
Either that or one [or both] hoses have come loose from the switch. I think it is pretty rare {not impossible} that the seal in the headlight switch goes bad. Verify the correct routing and connections first (if you can). Change headlight switch as a last resort.
Old Sep 28, 2009 | 03:07 PM
gbvette62's Avatar
gbvette62
If it's one of the repro switches on the market, it's quite possible that it's leaking. There had been a lot of trouble with repro switches about 2 years ago, and I'm sure that some of the bad switches are still flooting around out there.
Old Sep 28, 2009 | 03:08 PM
BigBlockTank's Avatar
BigBlockTank
I had a bad headlight switch when I bought my 69, replaced it, and the vacuum side of the switch came apart. It happens
Old Sep 28, 2009 | 03:33 PM
...Roger...
Did you see the repro switches with the vacuum valve mounted backwards ?
Old Sep 28, 2009 | 04:31 PM
Alan 71's Avatar
Alan 71
Hi Roger,
On the switch noted 'correct'.... which nipple gets the BLUE striped hose.... #2 or #3?
Thanks very much.
Regards
Aln
Old Sep 28, 2009 | 04:45 PM
Peterbuilt's Avatar
Peterbuilt
Port 3 gets the blue striped hose, it connects to the bottom port on the pull down switch.
Old Sep 28, 2009 | 04:55 PM
crf311's Avatar
crf311
Thanks all, Roger you were right, I had the hoses backwards on the switch. Man it feels great, 1st time in 25years I can pull the light switch and have the light come on and up, I never had the vacuum hooked up until after rebuilding due to Katrina. Replaced all the pcs and now it all works like it suppose to.
Old Sep 28, 2009 | 05:43 PM
...Roger...
Originally Posted by Alan 71
Hi Roger,
Thanks very much.
Regards
Aln
Alan , Pete is on the money #3
crf311 Glad you got it fixed, the system can be a little bit of a pain sometimes.
Old Sep 28, 2009 | 06:32 PM
Alan 71's Avatar
Alan 71
Hi,
I, too, believe the blue hose goes on the #3 nipple..... BUT..... I've been curious about what happens if you move the nipples to the 'wrong' position AND move the blue hose to the #2 nipple.
Did the switch/nipples change at some point and that's why the AIM is wrong?
Regards,
Alan
PS: I'm really only familiar with the 71 AIM, so I'm not sure what years might be right or wrong.
Old Sep 28, 2009 | 08:03 PM
Peterbuilt's Avatar
Peterbuilt
Default All the years may be wrong!
Hi Alan, here's a page from the 74 AIM, it is wrong too. PG.
Old Sep 28, 2009 | 08:42 PM
Alan 71's Avatar
Alan 71
Hi Pete,
Thanks for the picture.
It's interesting in that it appears to be the same drawing as in my 71 AIM, but has been modified with the changes that were needed when the wiper door was dropped.
I don't understand why the problem wasn't picked up by then.
It almost looks like in 74 they show the 2 hoses crossing right at the nipples. It would have been so easy to make the drawing clear!!!!!!
Thanks again!
Regards,
Alan
Old Sep 28, 2009 | 09:13 PM
...Roger...
Hi,
Regards,
Alan
It really comes down to the way the vac valves work. (The hose color is irrelevant) "ALL" the vac valves are the same. The nipple furthest away from the **** is the "ONLY" nipple that can dump the vacuum--and the vacuum must be dumped to send the signal to the relay to move to the up position.
Old Sep 28, 2009 | 09:19 PM
...Roger...
Maybe another approach would be to say that when any of the valves are pulled out the nipple furthest from the valve is open and "LEAKS" so you wouldn't want the supply line from the engine attached because you would have a vacuum leak.
Old Sep 29, 2009 | 05:06 PM
78pace's Avatar
78pace
crf311,
glad to hear you problem is solved. I have a related question. The maintenance switch, can they go bad? My head lights work but not the main. switch. Checked and looks like hoses are in the correct locations.
Thank you
To headlight switch vacuum leak
