How much HP
Old Oct 6, 2009 | 08:06 PM
glassman74's Avatar
glassman74
Default How much HP
Advice needed. How much HP will a stock 74 w/a th400 take.(street only) Have a stock L48 (190 HP) in it now. Nothing wild, just a little more Sh*t and Get.
Thanks in advance. glassman74 Save the wave
Old Oct 6, 2009 | 08:14 PM
Ganey's Avatar
Ganey
No problem. Way over 500+HP w/o slicks. Trans. are rated in TQ capacity.
Old Oct 6, 2009 | 08:42 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
my little TH350 handles 490 HP & 529 ft. lb torque
Old Oct 6, 2009 | 08:48 PM
7T1vette's Avatar
7T1vette
That will cover the transmission. What about the differential, U-joints, & half-shafts? I think if you double the HP, you will have problems with your 'pumpkin' & standard 190HP U-joints.
Old Oct 6, 2009 | 09:44 PM
Attfay Elleybay's Avatar
Attfay Elleybay
It's been said here before, The rearend can handle 600hp with street tires, 400hp with slicks. Of course those numbers go down with age.
Old Oct 7, 2009 | 08:20 AM
7T1vette's Avatar
7T1vette
I'm not sure why anyone would spend the money for an engine that will make 500-600 HP, then put street tires on it so that it won't break. If you only want to spin the tires, spend a lot less on the engine.
To How much HP
