Carpet Question? Willcox?
Old Oct 15, 2009 | 02:03 PM
Clams Canino's Avatar
Clams Canino
Default Carpet Question? Willcox?
This might be one for Willcox only... we'll see.
Because I spent 30 years disliking the 80/20 loop, I'm putting cut pile in my 1968 4-speed vert this time. (because I can)
I see that there's one set for the '70 only and another set for 71-75.
What's the difference?
My instinct is to get the 1970 for my '68 but I'm thinking they perhaps improved something for 72-75?
So what do I want and why please
-W
Old Oct 15, 2009 | 04:53 PM
1ATony's Avatar
1ATony
-W
The 68 & 69 carpets are the same, the floor pan may have changed on the 70,because the next fitment range is from 70-75.
Tony
Old Oct 15, 2009 | 04:57 PM
Clams Canino
Tony
Almost:
68-69 is one range
1970 is all by itself,
and 71-75 is the last
The differece could be as simple as molded in heel pad stuff. But I'd still like to make an informed decision based on *what* changed between 70 and 71.
Old Oct 15, 2009 | 05:04 PM
1ATony's Avatar
1ATony
According to ACC the floor was the same from 70-75,if there was a change in 71 it had to have been very minor. I'd also be interested in what it was if there was a tweak.
Old Oct 15, 2009 | 05:33 PM
Clams Canino
Well I can tell you this:
The difference is in the REAR of the convertible.
The front carpet sets are the same in the catalogs. The only difference being that the dimmer pad was added for 70-75. (actually late 69)
But they did change *something* in the rear of the vert after 1970 - I just don't know what that is - YET.
(or if I want that change in my 68 or not)
-W
Old Oct 15, 2009 | 07:38 PM
Ironcross's Avatar
Ironcross
1968 to 1977 has the same application except the materials and weave...plush, 80/20, 80/20 loop....78 to 81 is just the materials and colors...otherwise they are probably all the same and roadsters had nothing to do with it........
Old Oct 15, 2009 | 08:18 PM
Clams Canino
Theres more to it than that.
All the catalogs differentiate 1970 from 71-75.
-W
Old Oct 15, 2009 | 08:48 PM
Ironcross's Avatar
Ironcross
-W
Yes as 70 is plush, otherwise the same...actually 68`s correctly is 80/20 or 80/20 loop...if your a NCRS contender...the colors are important as not available for all years, however they could be as a special order and why years are specific..Otherwise they will interchange by year and fabric from 68-77 regardless whether coupe or roadster
Old Oct 15, 2009 | 10:35 PM
Clams Canino
Ya REALLY think so??
Now explain to me very slowly...
Why are the FRONT carpet sets all listed the same for 1970-1975...
but the REAR carpet sets separate 1970 from 71-75.
And please spare me the story about a different color used in the rear as opposed to the front color.
-W
Old Oct 15, 2009 | 11:10 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Clams... I've not read all of this, but I will tomorrow. But, I can get you the 68 carpet in cut pile if this is what you are wanting. Then it will install without any problems.
Sorry for the short answer tonight, I have to run... If I've not answered this right I'll check back in the morning.
Willcox
Old Oct 15, 2009 | 11:49 PM
Clams Canino
I'm just kinda wanting to know what changed about the rear vert carpet to cause 1970 to be listed seperately from the 71-75 in all the catalogs ??
-W
Old Oct 16, 2009 | 04:36 PM
Clams Canino
That.. and I want the pad they added in late 69 as well.
And I'm just a curious kind of fellow.
-W
Old Oct 16, 2009 | 05:11 PM
Alan 71's Avatar
Alan 71
Hi,
I believe 68s and most of 69s didn't have dimmer pads. Then 70s had no dimmer pad again (maybe a few left over from 69 had the pad) while 71s and 72s did have the pads.
I believe the heel pad for 68 to early 71 had ribs that ran to within 1/4" of the top of the pad, while late 71s and 72's had ribs that stop 3/8" short of the top of the pad.
Clams,
I believe 70 is seperate because in 70 the rear carpet went further up the rear bulkhead and further into the corners.
I think this is all NCRS detail, not how the carpet fits.
Regards,
Alan
Old Oct 17, 2009 | 02:40 PM
Clams Canino
That's closer to what I was looking for. I'm not so sure about the lack of a '70 dimmer pad or when it stops and starts. Some of the catalogs have a different set for 1970 front only and some don't. But all of them have the complete and/or rear only sets singling out 1970. I find this all strange but fascinating.
-W
Old Oct 17, 2009 | 03:33 PM
Alan 71's Avatar
Alan 71
Hi CC,
My feeing is that the 70 carpet went 4-5" further up the rear compartment bulkhead. My 71 stops about 1" above the position of the mounting plugs.
Regards,
Alan
Old Oct 17, 2009 | 04:47 PM
Clams Canino
If we're talking about the very rear of the compartment, The original in my 68 vert went almost up to the astro-ventillation thingies in the back. Are you saying that in your vert it stops way down near the floor? I'm not sure what a "mounting plug" is yet?
-W (possibly getting confused on terminology)
PS: to those reading the thread... sooner or later we all stand to learn a great piece of Corvette trivia - I can feel it.
Old Oct 17, 2009 | 05:54 PM
7T1vette's Avatar
7T1vette
"Mounting plugs" are the rubber plugs that were used to hold vertical carpet sections up to lay flat on the surface. They are about 2" long and 1/4" in diameter with a 1/2" head. There is a hole formed in the plug from the top of the head to nearly the end of the plug; a tool was used to fit in that hole for installing the plugs through the carpeting and the hole in the body panel. You can still buy those plugs if you want to use them rather than glue. BTW, glue gets old and loses its grip on vertical carpeting...plugs do not.
To Carpet Question? Willcox?
Old Oct 17, 2009 | 07:46 PM
Clams Canino
The only place I can see a remnant of such mounting plugs is on the vertical metal bulhead behind the seats - is that where you meant? I thought you were talking about the way way back wall of the rear cpmpartment.
On mine the carpet went all the way up that wall and folded over toward the 3 little doors.
-W
Old Oct 18, 2009 | 11:01 AM
Alan 71's Avatar
Alan 71
Hi W,
I was referring to the fiberglass bulkhead that's at the rear of the rear compartment, not to the metal bulkhead that's right behind the seats and part of the birdcage.
As 7T1 said, the plugs are for the rear bulkhead, coupe or convertible. The carpet was glued to the steel bulkhead behind the seats.
Regards,
Alan
You can see the 'swish' of glue on the steel bulkhead.
And no glue on the rear bulhead, but 2 of the 3 plugs still in place instead.
Old Oct 20, 2009 | 10:00 PM
Clams Canino
OK... what I was seeing was rivets behind the seats.
But my '68 car never had the plugs on the very rear iether. I have glue going *all* the way up to the astro vent thingies. No holes, no plug remnents, no nothing. No wonder I was confused.
-W
