Differential Bracket
Old Nov 30, 2009 | 06:31 PM
271vette's Avatar
271vette
8th Gear
Default Differential Bracket
My recently puchased 71 coupe has a different set-up for the rear diff to frame mounting bracket. It looks as though it may be an aftermarket set up of some sort, the bracket not only mounts the diff to the frame but it extenda back to the rear spring and is used in place of the bracket that holds the spring to the diff. Has anyone seen this set-up before?? I am going to replace it with stock but I am curious as to why someone would use this set-up. Thanks
Old Nov 30, 2009 | 11:06 PM
MelWff's Avatar
MelWff
can you provide a picture?
Old Dec 1, 2009 | 01:46 AM
rpoL98's Avatar
rpoL98
kinda sounds like the drag bar.
Old Dec 1, 2009 | 03:55 PM
Alan 71's Avatar
Alan 71
Hi271,
Here's a couple of pictures from my 71 that may help you khow what the stock pieces were.
Regards.
Alan
To Differential Bracket
