TO replace or not replace (heater core)
Hello All,
Thanks again for your continued help; I'm thinking about replacing my heater core.
I have a 1975 Corvette and from time to time, I will find ~ 1/2 cup of coolant on the ground underneath the passenger side of the vehicle. I showed a mechanic my heater hoses (that's where it's dripping from) and he was sure my heater core is leaking.
Is this a difficult project?
Expensive etc? I may not know what I'm doing, but I'm more than willing to put in the time to learn how to do it.
Is it a relatively simple process, just very time consuming?
I was told to just link the two hoses together and zip tie them to the car; is this acceptable? From what I've read, the heater core is pressurized; will this prevent coolant leaking into my passenger compartment?
I don't use the heater to begin with, so I can live without it... how can I be sure it's the core?
Thanks again for your help...
Semper Fi!
Felix
Semper Fi!
Felix
Red Road Warrior
St. Jude Donor '10-'11, '15, '19
I will tell you a little "Bubba" I did when I discovered my heater core was leaking (the day before my clubs big show).
I put an adjustable wood clamp on each hose to cut off the water circulation. Removed each hose from the heater core. I forced a piece of capped 1/2" copper tubing in each line a couple inches from the core lines. Put a clamp on each hose where the copper tubes were & reconnected to the heater core. This lasted me the whole summer - I replaced the heater core over the winter.
One suggestion IF you ever replace the heater core - take the new core to a radiator shop and have them pressure tested AND reinforce the solder joints where the tubes attach to the core. I learned this the hard way on both my 69 & 78! Installed straight out of the box - both leaked at that poorly soldered joint!
And no, I didn't find the replacement to be too difficult.
John
John
John
John
Hi John,
Thanks for the reply, why the wood clamp? I know I'm asking the same question twice, but can't I just disconnect the two heater hoses and put a U joint between them to close the circulation? I don't understand how / where I should do this bypass? I just thought I would disconnect the two hoses and link them together?
F
Most people would consider changing the heater core a challenging project. Since you don't use the heater, you can simply remove the heater hoses entirely and install pipe plugs at the intake manifold and water pump. No bypass is required. My car has this setup with no problems.
Hi John,
F
F
F
This pic is from before I removed the AC evaporator & housing. You can see the two plugs. They are just pipe plugs from Home Depot, 1/2 inch and 5/8 inch I think. It reduces clutter but doesn't add horsepower.
F
One plug is on the intake manifold just below the rad hose connection in the picture. The other is down on the passenger side of the water pump. They are the same locations where your heater hoses connect to the engine.
1 Post
Cruise-In VIII Veteran
http://www.corvettefaq.com/c3/heatercoreremoval.pdf
When my heater core failed ( I wanted to postpone the core replacement work until later) I went to an auto supply store and asked the clerk if he had a heater hose that was 5/8 on one end and 1/2 on the other. He found one and when I got home I cut the hose to make short loop of hose right at the engine end. I attached the hose to the fittings on the engine with the original hose clamps. I removed/discarded the old hoses from the end of the heater core. I ran the car this way for about 11/2 years. As for the heater core replacement it is not a difficult task but is long and tedious. There are several good references on the internet about the steps to do this job, many with pictures taken during the process.
Here's a post I made sometime back. It's on an '80. Yours has a split dash, so it will be a bit different. Once you get to the heater box, I believe they're the same though.
Best,
Felix
I just finished mine yesterday, and here's the thread
http://forums.corvetteforum.com/c3-t...ater-core.html
