Interesting, but wouldn't the fuel just blow out the exhaust?
Have you ever seen a carb fire? There are two valves that can be open. If the fuel is not burn and ignites at just the right time in the exhaust, or by an intermittant spark, it can travel into the intake. YOu introduce raw fuel/air into the cumbustion chamber it doesn't burn and then you pump that raw fuel/air into the exhaust a the same time you are bringing raw fuel/air into the combustion chamber again. At this point you have a complete path of unburned raw fuel/air mixture in the exhaust, combustion chamber and intake at the same time. If that fuel mixture happens to ignite when both valves are open, you have the scenerio I just described.
If you recognize basic Otto cycle theory, it isn't too hard to realize.
Yes, singed my eyebrows actually. Intake ignition is actually as a result of the mixture being too lean believe it or not. When there isn't enough fuel in the air to keep it cool it can ignite from just the heat in the intake, as is my understanding. This is why after I upped the size of the discharge nozzles in my Mighty Demon there were no more carb fires.
Case in point, intake fire and exhaust fire are caused by two different things.
