Engine cuts out and stalls while driving.
Old Feb 4, 2010 | 10:19 PM
enkeivette's Avatar
enkeivette
Default Engine cuts out and stalls while driving.
Blown 383 SBC, Annular Mighty Demon 750 Carb with an MSD HEI.
Car idles ok, but as the RPM builds, the motor cuts out completely and stalls. Seems to be independent of throttle position, and only RPM related. Car restarts after stalling.
What is the cause?
Old Feb 4, 2010 | 10:51 PM
c3corvette77's Avatar
c3corvette77
is the fuel pump putting out? is the carb tuned properly?
Old Feb 4, 2010 | 10:53 PM
FlyViper's Avatar
FlyViper
Maybe fuel starvation. Does your fuel pump have a high enough flow rate? Even without stomping on the throttle, at a continuous 5000 RPM maybe the pump just can't handle the required flow.
Old Feb 4, 2010 | 11:01 PM
Goody's Avatar
Goody
Fuel bowls not filling up completely?
Fuel filter clogged up?
What do the spark plugs look like? They probably look leaned out.
How much fuel pressure are you getting at the carb?
Old Feb 4, 2010 | 11:19 PM
enkeivette's Avatar
enkeivette
Bowls are full, up to the top line in the sight glass window after stalling. Fuel pressure guage reads 7psi at atmospheric level, increases 1psi per lb of boost. Carb is tuned at 12.5:1 under boost and 14.5:1 light load low rpm cruise.
Old Feb 4, 2010 | 11:20 PM
enkeivette's Avatar
enkeivette
Motor is cutting out at around 2K-3K, light throttle. Fuel pump has kept up in the past with WOT 13lbs of boost runs.
Old Feb 4, 2010 | 11:21 PM
enkeivette's Avatar
enkeivette
Fuel filter is relatively new. Spark plugs are burning perfectly tan.
Old Feb 4, 2010 | 11:43 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
A coil can get hot, copper expands and open circuits, but that normally takes a few minutes to cool off for a restart and it probably wouldn't necessarily cut out at the same rpm every time.
And i've not seen a module have a failure mode like that either. Mostly once they fail they're done.
Old Feb 4, 2010 | 11:52 PM
enkeivette's Avatar
enkeivette
It will cut out when the motor is still cold, restarts immediately. I'm thinking ignition too though, doesn't sound like a fuel issue to me. What should I check?
Old Feb 5, 2010 | 12:00 AM
DRIVESHAFT's Avatar
DRIVESHAFT
Can you cause it to act up in Park/Neutral, or do you need to be moving?
Old Feb 5, 2010 | 12:01 AM
enkeivette's Avatar
enkeivette
Only seems to happen under load. But it feels like there is a slight misfire in neutral.
Old Feb 5, 2010 | 12:29 AM
turtlevette
i notice someone is telling you to replace the whole dizzy on the other site.
You can get a module for $20 at autozone to test your MSD unit. If that's not it, you have a spare to carry with.
Old Feb 5, 2010 | 10:38 AM
turtlevette
It could be a boost issue. That's right about where a centrifugal blower starts building pressure. But you know that. I'd be helpful if you'd look at the boost gauge and tell us if that has some relationship. The pressure is probably preventing gas from entering the bowls because you have a loose feedback hose on your regulator to signal a boost in pressure as the boost increases.
Old Feb 5, 2010 | 10:55 AM
mrvette's Avatar
mrvette
Wouldn't that cause the engine to sputter and stumble like MAD, quit firing and then catch as the rpm's fell?? kinda like pulling 1/2 the injectors offline...??
how about the rev limiter resistor?? they got a plug in for those later model MSD units I have never owned/messed with one, except very casually, so wonder what happens if the programming resistor is left out??
Old Feb 5, 2010 | 11:17 AM
turtlevette
Yea, i thought about that too. It depends on the recovery time ie, how fast can the fuel bowls fill and start providing fuel again. Is the engine in coast mode and still turning to restart or is he clutching or shifting to neutral after the stall? He's not giving us the full story. He knows what the answer is and is doing this as a test to see which site has the "smarter" guys.
He has an MSD HEI which is just like a GM HEI with MSD module and coil. The digital module does have a rev limiter. The analog one like i have doesn't.
Old Feb 5, 2010 | 04:05 PM
enkeivette's Avatar
enkeivette
If the problem is independent of throttle position, then it wouldn't be a boost issue. Under light acceleration (vacuum) the BOV is open bleeding boost.
Old Feb 5, 2010 | 04:29 PM
Rich's'78's Avatar
Rich's'78
Also check that the gas tank is venting adequately by removing the cap.
To Engine cuts out and stalls while driving.
Old Feb 5, 2010 | 04:31 PM
enkeivette's Avatar
enkeivette
Issue-> spark plug melted on header, caused short.
Old Feb 5, 2010 | 05:08 PM
DRIVESHAFT's Avatar
DRIVESHAFT
Nobody on either site guessed that a plug wire being grounded to the header caused the problem.
And truthfully, if thats all you found, I would be really surprised if that was what caused it.
One shorted wire causes a dead cylinder, not total shut down.
Old Feb 5, 2010 | 05:32 PM
mrvette's Avatar
mrvette
Assuming that one wire was not the external coil wire, but he did say it was a 'standard HEI'....
