From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by eagle275
and Quadra-Jet carbs? Thanks for the info.
The Carters were used on Mopar, and have four similar sized throttle bores. The Rochester Qjet GM used on hundreds of millions of cars has very large vacuum operated secondaries. It is the most misunderstood carb of all time and arguably the most common.
The AFB (AFB = "Aluminum Float Bowl") carb (now touted by Edelbrock as a "performance" carb) was deemed obsolete by GM in 1966 and replaced by the more advanced Q-Jet. The Q-Jet, contrary to popular misconception, is not a vacuum secondary carb, but a mechanical secondary carb with an airvalve, and most Q-Jets flow 750 cfm. They can be tuned to an outstanding level of performance, and will typically outperform any AFB style carb once correctly set up. A new Edelbrock AFB will easily outperform an incorrectly set up Q-Jet, but this can be said for any carb comparison.
Hi Paul!!! I'm keeping my Centerline Mug full and in use at all times!
Lars, are the Edelbrock Q-Jets any good?
The Edelbrock Q-Jets have been discontinued for about 4 years now, so you can't find a new one. The "Edelbrock" Q-Jets are genuine Rochester Q-Jets made using the original tooling under contract to Edelbrock (EDL didn't make them themselves), so there is no difference between the EDL Q-Jet and the Rochesters. The EDL carbs are the "truck" version Q-Jets, so beware that you cannot use the hi performance "passenger car" primary metering rods in the EDL integral choke carbs, nor can you use the EDL primary metering rods in your correct 1975+ Vette Q-Jet.
I believe it's AFB - aluminum four barrel (w/mechanical secondaries) and AVS - aluminum vacuum secondaries (w/vacuum operated secondaries). I thought they were set up like the Q-Jet w/ smaller primaries and larger secondaries. I know that they did have a AFB set made exclusivly for the super stock hemi's that had the same size barrels, spell that HUGE!!! I had a pair on a 68 hemi and found out they only made a hundred pair of them and because they were so rare, Carter didn't even have the jetting information on them anymore. Took a lot of digging to get the right info on them and boy were they some extremely thirsty carbs... never could keep any gas in that tank.
Main difference between a AFB and a AVS is secondary opening, the AFB has a counterwieghted air butterfly, and the AVS has a spring loaded one as I recall from my Mopar days. The only way to adjust AFB secondary opening is by drilling weights, AVS is a turn of a screwdriver.
Also many might not know this but some very early Qjets were made under contract by Carter and have a "Carter" emblem cast into their main-bodies.
Myself, I'll stick with the crappy fuel curve of a Holley because I want to corner my Vette at high G forces. I'll save the other carbs for my pick-up truck.
Originally Posted by 76GlassY
Off one of the carb sites: AFB - aluminum four barrel, AVS - air valve secondaries.
I'm sure the web site is right. I just used to teach as an instructor for the GM Training Center, and I'm sure GM had it wrong when they gave us literature showing the AFB to be "Aluminum Float Bowl" due to the one-piece cast aluminum bowl. I'll be sure to redline my GM Instructor's Manuals and change the designation.
Lars
GM manual vs. Internet? Didn't Al Gore invent the Internel?
Al Gore says AFB = "Aluminum Four Barrel" and that Global Warming is going to destroy us all. What was I thinking...??? I should throw away all factual information about everything, quit arguing "Internet Facts," and succumb to myths, notions, and popular opinion. I'll get along with a lot more people that way (very important to me, as I'm sure you've noticed).
For thought...
Both Rochester and Carter (and even MotorCraft) designated their carbs not as "barrels," but as "venturies." A 2-barrel carb was a "2V" carb, and a 4-barrel carb was technically described as a "4V." If the Carter AFB was, in fact, described as an "Aluminum Four Barrel," the designation would have been....
"A4V"...
In the meantime, I'll be building some killer stuff out in my workshop, and I hope to meet up with some of the "Internet Racers" at the local stoplights for some sporty wagers...
Here is a quote from the Carter AFB Tuning Manual provided by Federal-Mogul Technical Education Center (owned Carter)
BTW, Federal-Mogul Carter sold the Carter AFB, tooling and manufacturing plant in Sanford N.C. to Magnetti-Marelli (Weber) in the late 80's. Carter and Edelbrock ran on the same assembly line.
Carter, for Federal was not worth more investment and gave up the performer afb around 10 years or so ago.
Originally Posted by noonie
Good, factual info. Now we have 3 terms, "Aluminum Four Barrel," Aluminum Four Bore," and "Aluminum Float Bowl." I think we can toss out the "Aluminum Four Barrel" designation since there is no Carter/Federal/GM documentation to substantiate that one. I have the GM-provided training material in my hand that uses almost the same description as that shown in the above Carter/Federal tech paper regarding the main body design and no gaskets below the fuel level, but it uses the term "Aluminum Float Bowl" to describe the AFB designation for this reason. It was published in 1972, and carries GM and Carter logos - there is no Federal/Mogul endorsement on this 1972 document, making it quite possible that the acronym designation was altered between the 60's and the time that Fed/Mogul got involved. Noonie - is there a date on your document? Would be interesting to see if there was an evolution in the acronym or if GM and Carter used different terms for the same carb.
Lars
Lars, you guys really taxing my mammory now, as I recall, the olde tyme Mopar guys always used Alum. Four Barrell, and the term Barrel was more common in the Maryland region than the term Venturi....and I do agree that most 'factory' type papers used V instead of B,
I wonder what Mopar folks say on that point....I dunno where to look...
I just remember seeing a Hemi with dual quads on it AFB's....and the cross ram 413? engine, an old Mopar buddy had a set of the cross ram induction all polished up and setting on his coffee table....
Lars
Well, I guess this can be considered official since it came directly from a Carter published manual with a pretty early date.
The FM manual I have has no dates, but must be after '85 or therabouts when Federal-Mogul aquired Carter from ACF Industries, the parent company. FM had a huge history in the 70's and 80's of buying automotive suppliers.
Carter also included the term "downdraft" since they also made updraft and what they called "horizontal" carbs (what we mostly know as "side draft").
