Starter Wiring Help!
FYI . . . the starter was working fine (removed it when changing spark plug wires).
Thanks for your help! As a new owner, I'll take all the help I can get!!!
Knowing your car's year would help.
My 71 starter solenoid has 4 wires, the BLK #2 and the BRN #14 to the B post, a PPL #12 to the S post, and a Y #20 to the R post.
Hope this helps some.
The harness near the starter is often in bad shape since it's so low to the ground and so near the exhaust manifold. DIRT and HEAT.
Regards,
Alan
Your 76 had 2 fusible links that were crimped into 1 large terminal.
In your pic the wire on the left is the 12 purple and it goes on the S terminal.
The very large black wire to the far right is battery cable.(you knew that )
Whats left are the 2 red wires. As 7t1 said are fusible links and 1 appears to be burnt in two. You should replace both fusible links. Go back behind the large black plastic cylinders and cut the red wire. Buy 2 new fusible links (autozone has them) and crimp them on the red wires,you will now have 2 large round terminals instead of the factory 1. Put both new fusible link terminals and the battery cable on the large solenoid stud.
You will not have yellow on your 76.
You should also have a black 14 (that is not shown in your pic) in that harness, it is a ground for the blower and wiper and has a large round terminal **** DO NOT PUT IT ON THE SOLENOID TERM along with the fusible links. It should go to the engine block for ground( i put it on 1 of the bellhousing bolts).
Hope this clears up the difference in 76 starter wiring.
note - the large black plastic cylinders are not the fusible links,the link is the wire.
Here is a thread about links. The link I posted a pic of is an inline link and has 2 plastic crimps.
http://forums.corvetteforum.com/c3-g...ble-links.html
