More 68 Resto Pics
Old Mar 1, 2010 | 01:21 AM
76yellow's Avatar
76yellow
Default More 68 Resto Pics
Front Clip RepairsFrame Blasted, Sealed, Primed & coated with Black EmronReady for the BodyI Changed from the 4 spd to a 2004R for the OD. Also going with Hooker Headers & side exhaustAfter Market L88 Hood fit poorly so I took a 76 hood & fabricated the L88 center into itRemoved the metal trims on the 68 fender corners & molded the corners to match up to the hood & doorsThe 396 tucked in nice & snugComposite suspension front & rear & thru some primer on so I could test drive it. YA HOO
Old Mar 1, 2010 | 09:50 AM
Alan 71's Avatar
Alan 71
Hi 76Y,
I'm still enjoying your pictures.
It's interesting to see what people do with cars and especially to see how they figure out how to make things (the hood) work.
I hope there're more pictures.
Regards,
Alan
Old Mar 1, 2010 | 09:53 AM
WESCH's Avatar
WESCH
Hi
I'm impressed.
Keep the pics coming.
Brgds. Günther
Old Mar 7, 2010 | 05:09 PM
mydejavooo's Avatar
mydejavooo
So which vendor did you end up getting the hood scoop from? That's exactly what I want on mine, and it looks like yours is the right dimensions for the Corvette hood.
Deja
Old Mar 7, 2010 | 11:55 PM
mydejavooo's Avatar
mydejavooo
And can you snap a photo of the underside of the hood as well? Thanks!
Deja
Old Mar 7, 2010 | 11:58 PM
jordan89's Avatar
jordan89
Originally Posted by Alan 71
Hi 76Y,
Regards,
Alan
Great pictures, and great projects. As always, they look really nice.
Old Mar 8, 2010 | 09:54 AM
Z068's Avatar
Z068
Default Rad/core support
Awesome project, looks like your about 6 months in front of me. Question, can you lower the body over the core support with the radiator in place? The support was so tight coming out I don't see how.
Thanks,
Steve
Old Mar 8, 2010 | 10:07 AM
76yellow's Avatar
76yellow
I don't know the vender for the L88 hood. I got it on e-bay because it was what I wanted. But when I put it on it had wide gaps on the sides where it met the fenders so it looked terrible. I bought a 73 hood & cut the center out of the L88 hood, layed it on the 73 hood, marked it & cut the 73 hood out & glassed the 2 together. As you can see in the pics, I used a bunch of metal tabs to hold everything in place & glassed the back side first. I also had to add 3/4" to the rear corners of the hood to match the fender corners I fabricated. The 68 fenders had metal trims to match the wiper door which I removed. I'll post some pics of the back side soon.
Old Mar 8, 2010 | 10:21 AM
mydejavooo's Avatar
mydejavooo
Looks like it was made for a longer hood.....on the "newer" C3's. I don't think I'd have that problem on my 76 hood, because I don't have the wiper doors. Do you know what the measurements were on the scoop?
Deja
Old Mar 8, 2010 | 08:38 PM
76yellow's Avatar
76yellow
Deja...Here are a few more hood pics
Old Mar 8, 2010 | 08:54 PM
mydejavooo's Avatar
mydejavooo
Dang! That's sweet......and EXACTLY what I want to do to mine. BTW, did you have any trouble with those M/T covers hitting the brake booster??
Deja
Old Mar 8, 2010 | 10:20 PM
76yellow's Avatar
76yellow
No, but its close. I think I have about a 1/4" clearance. The alternator was a bigger issue. Not much room for adjustment. I had to find a belt that would work with very little adjustment. The hood was a challenge & time consuming to build but I really enjoy working with fiber glass. Let me know if I can help you with yours. We probably better do it by e-mail as there might be some on the forum that are'nt interested in this. I don't want to offend anyone on this forum. I love this forum & have recieved lots of help & advise.
Old Mar 13, 2010 | 05:12 PM
mydejavooo's Avatar
mydejavooo
You must have found a realllllly long scoop, or did a LOT of modifications to that scoop in order to get it to fit right! I just got one from Summit, and it's nowhere near as big as the one you have, and is going to take quite a bit of modification in order to get it to work properly. If it's lined up at the back of the hood, there is a space about 3 inches wide between the bottom of the scoop and the old hood. If you scoot the scoop more forward, the space is less, but then the scoop ends near the front of the factory hood vent. So the guys that are going to put that scoop on for me definitely have their work cut out for the them! And I was also surprised as really how thin the fiberglass is on their scoops. I'm going to have to have them beef that up, since I would say it's almost borderline "flimsy". A little disappointed in Summit's scoop.
Deja
Old Mar 13, 2010 | 06:07 PM
john roth's Avatar
john roth
Keep em comin !!
Old Mar 13, 2010 | 07:11 PM
7T1vette's Avatar
7T1vette
Dandy job....
Old Mar 13, 2010 | 07:58 PM
oldsarge's Avatar
oldsarge
Lookin good ! nice work, good job on the hood.
Old Mar 14, 2010 | 03:17 AM
mydejavooo's Avatar
mydejavooo
Default All hood scoops are NOT created equal!
I was so motivated by your hood scoop install that I ordered mine and I got it yesterday. It's a Summit Racing scoop....and it's totally different than the one that you have, which is not a good thing. The one you have is really long, and really wide, making installation a lot easier. I got the tallest one I could find, but to get it to sit where I want it, there is a HUGE gap (maybe 3") on the sides...between the bottom of the scoop and the hood itself. Also, the contour of the stock cowl is wreaking havoc on how it will sit on the hood. This thing is going to take some massive amounts of fiberglass filler to take up the gap there. I'm a bit disappointed in how thin their scoop is too. It's really thin, and it is going to need some more fiberglass mat in order to keep it from being sooooo thin. You can see in the photos that I took, exactly what I am talking about....not pretty. May have to rethink this one.
Did your scoop have the same "fit" issues?? Any advice on this "gem"??
Deja
To More 68 Resto Pics
Old Mar 14, 2010 | 01:57 PM
76yellow's Avatar
76yellow
I see what your saying Deja. I don't know what year hood you are starting with but looking at your pics, if you cut some of the high part out of the middle of the hood your scoop should drop down & lay on it. Then you can mark around the scoop to see what you have to really cut out. Being a flimsy scoop is probably a good thing at this point. You can beef up the scoop on the back after it is glassed to the hood. Your on the right track. You got the idea there. Zeeth
Old Mar 14, 2010 | 02:30 PM
stinger12's Avatar
stinger12
Before you do anything, I would finish stripping the paint off of the hood. I also wouldn't start fitting the scoop until you fit the hood to the car. Don't put the cart before the horse
Old Mar 14, 2010 | 03:33 PM
mydejavooo's Avatar
mydejavooo
I did forget to mention that the hood sits up like that because I have a spray can lid under the back of the scoop. I did that because I wanted to see where I actually want the height of the scoop. There IS less distance between the scoop and the hood if I take that cap out of there, but then the issue is the height of the scoop. I don't want to go through all of the hassle of grafting this thing and not get the extra clearance for my 454. I thought it was going to be a lot taller at the back of the scoop, but when laid down, it's maybe only an inch taller at the back. Granted, you get some extra height towards the front...but still not what I wanted. If it wasn't a boatload to ship those hoods from Ecklers, I'd just order one and be done with it...but it's like $200 bucks on top of the $700 hood!
And how do you know how far forward or back the scoop is supposed to sit on the hood??
Deja
