Vacuum Tank Replacement
Old Mar 8, 2010 | 05:52 PM
MIKE80's Avatar
MIKE80
Default Vacuum Tank Replacement
Okay, got another part I need to replace that seems hard to find. I looked around and it seems that nobody has replacement vacuum reservoir tanks for my 80. Anybody know where to get one?
Also, has anybody used an aftermarket tank other than the coffee can original style?
Old Mar 8, 2010 | 07:04 PM
john roth's Avatar
john roth
I was able to get a new one at Paragon for my 1969. Have you tried them ?
blaine@corvette-paragon.com
Old Mar 8, 2010 | 07:33 PM
bluthundr's Avatar
bluthundr
I have heard of people sealing small leaks by taking it out, capping all the ports except one, pulling a vacuum on the can, spraying it with rattle can undercoating, and then letting the vacuum off. Doing this is supposed to pull the undercoating into any pinhole leaks and seal them up.
Old Mar 8, 2010 | 07:51 PM
...Roger...'s Avatar
...Roger...
Make your own.
Old Mar 8, 2010 | 08:10 PM
MIKE80's Avatar
MIKE80
Mine is banged up pretty good, rusted, and leaks. That's why I want to replace it.
I could not find one on Paragons website.
I thought about cutting out the valve on the top and installing it into another type of canister, but I'd rather replace it if I could find one.
Old Mar 8, 2010 | 08:30 PM
7T1vette's Avatar
7T1vette
The best source for these is a Corvette parts swap meet at some Corvette 'shindig'. The next best place would be eBay or a salvaged Corvette parts business (check the internet or ads in Corvette magazines for possible sources). If your tank has some rust/holes in it, just clean off the outside surface in those areas and slap some JB Weld epoxy over the leak areas. It is a vacuum tank, so "it sucks"...thus, patches need to be on the outside of the tank. If you use some semi-flat black paint on it when you get done, the thing is so buried in the fender, no one will notice.
Old Mar 8, 2010 | 10:42 PM
Fonz69's Avatar
Fonz69
Here are some from Summit
http://www.summitracing.com/search/?...resivior&dds=1
I bought one from there and it works great
[IMG][/IMG]
Old Mar 9, 2010 | 06:57 AM
...Roger...
Thats very easy to do, coffee can or juice can works great and paint it black. If you look at the factory coffee can style you can sometimes see under the black paint a name, I've seen Folgers several times.
Old Mar 9, 2010 | 09:29 AM
7T1vette's Avatar
7T1vette
Coffee cans are 'corrugated' to add strength to the can surface; that keeps it from collapsing. Coffee does come in a vacuum to keep it fresh, so a coffee can will do the job. But where do you find one that is assembled and sealed up...but doesn't have coffee in it? Smooth steel cans are at risk for collapsing if they are not a thicker gauge steel.
The stock vacuum reservoir has rounded 'corners' to spread the stress out over the surface, so you shouldn't use a box/cube unless it's sturdy, either. Anything made to accept pressure is probably suitable for use as a vacuum tank.
For that matter, you could probably make one out of 6" PVC pipe with end caps. Drill some holes for tube fittings and you're done.
Old Mar 9, 2010 | 03:47 PM
...Roger...
Just cut a 3/4" hole in the center of the coffee can and the coffee comes out easily and solder the original nipple set back over the hole.
Large V8 juice cans work fine also even though they are smaller in volume than the coffee can. PVC works good and you can just screw your fittings in.
Old Mar 10, 2010 | 07:38 AM
MIKE80's Avatar
MIKE80
Are all 3 vacuum line connections just straight through, or do they have a check valve in them?
Old Mar 10, 2010 | 08:03 AM
...Roger...
Straight through,pretty simple setup.
Old Mar 10, 2010 | 08:41 AM
7T1vette's Avatar
7T1vette
It is merely a holding tank, so that fluctuations in vacuum level will be 'smoothed out'. The check valve in the 'feed' line to the tank is the only one that is needed.
Old Mar 11, 2010 | 12:39 PM
MIKE80's Avatar
MIKE80
Thanks for the input! I'm going to see if I can come up with some aluminum and make my own tank.
Old Mar 11, 2010 | 02:26 PM
doctorgene's Avatar
doctorgene
Yes Sir: Eckler's has them brand new, Page 8 Part # 23065 1-800-327-4868 I used one, looks and works just like the Original. Have a great day. Gene
Old Mar 11, 2010 | 02:56 PM
MIKE80's Avatar
MIKE80
Item Discontinued.
http://ecklers.com/product.asp?pf_id=23065&dept_id=1255
Old Mar 11, 2010 | 04:41 PM
Cmflorida's Avatar
Cmflorida
Cruising
Default Hope this helps.
These are not easy to find, but I think I found you a vendor that still carries them.
Try J&D Corvette. Their number is (800) 838-8353
They got a website too, but if you want to make sure they have it in stock call the number and ask for "Adrian".
I think they are about $60 bucks tho. Might be a lot cheaper to make one as suggested above. Good luck.
http://www.parts123.com/parts123/yb....adffegc~R800~~
To Vacuum Tank Replacement
