Radiator Hose keeps blowing off
Old Mar 16, 2010 | 09:50 PM
  #61
enroberts's Avatar
enroberts
This is similar to the cap I have now...
Old Mar 16, 2010 | 10:17 PM
  #62
dannyman's Avatar
dannyman
Coolant flow goes from the radiator, through the lower hose and to the water pump. Blowing off the top hose would be caused by a rad blockage or the lower hose collapsing. You need to have the spring in the lower hose to ensure the hose is not collapsing under suction from the pump.
The lower hose installation with the spring is where I would start.
Old Mar 16, 2010 | 10:30 PM
  #63
noonie's Avatar
noonie
Looks good, but you can't tell from the top, turn it over and the brass or ss disk on the bottom will be spring loaded and not just flap in the wind.
If you ask for the proper one for your car, you should get the right one, just check the poppet.
Don't forget to mist the rad with a hose if not running a shroud.
Old Mar 16, 2010 | 10:36 PM
  #64
OMF's Avatar
OMF
Not all lower hoses have (or need) a spring. I have a lower hose without a spring, and have no cooling troubles at all. I think the construction of the hose, and maybe the type of rubber used, enables the spring to be deleted.
Old Mar 16, 2010 | 10:40 PM
  #65
dannyman's Avatar
dannyman
I agree, but having the spring in place ensures that the hose won't collapse.
Old Mar 16, 2010 | 11:53 PM
  #66
Mike Ward's Avatar
Mike Ward
That's correct. Modern hoses have no need for the spring.
Old Mar 17, 2010 | 07:25 AM
  #67
tommyleea's Avatar
tommyleea
I always thought the spring was used in "the old days now" due to the procedure the plants used to service the cooling system; can't remember what that procedure was now, however; they weren't needed for normal operation.
Old Mar 17, 2010 | 07:32 AM
  #68
tommyleea's Avatar
tommyleea
I don't think the cap is your problem. Under normal circumstances, your cap shouldn't have to vent. If there is too much pressure, you have other problems. Seems to me if the pressure is extreme, it would shoot out the top of the radiator, while running with the cap off.
Old Mar 17, 2010 | 08:40 AM
  #69
John Dingman's Avatar
John Dingman
There were actually two different radiators used from 77-82 and the only difference was the upper hose size. 1977-79 has a 1 1/2" hose and 1980-82 has a 1 1/4" hose. My guess would be you have a later model replacement radiator with the 1 1/4" radiator connection and the early 1 1/2" hose. That will blow off every time.
Old Mar 17, 2010 | 08:52 AM
  #70
damoroso's Avatar
damoroso
John,
That's interesting and I'd have never have guessed there were two sizes on those radiators, see, that's why it's good to have experts available!!
Old Mar 17, 2010 | 08:35 PM
  #71
enroberts's Avatar
enroberts
holy crap...you're dead on here. According to the radiator specs, the inlet is 1.31 inches, outlet 1.56 inches. My hose specs read I.D. 1.5!!!! I'm going to pep boys tomorrow for a 1.25 ID hose. THANK YOU SO MUCH FOR TELLING ME THIS....I never would've known that.
On a side note, I changed the cap and double clamped the hose (which I now know is too big) and ran the car to temp for 25 mins....no popping off. Now I know the real problem and can go back to a single clamp. I'm sure it would've only been a matter of time until it popped off again anyway.
I really appreciate everyone's time on helping me with this. Sorry it was something so stupid, but I have learned a lot about an area I was previously not very knowledgeable in. THANKS AGAIN. -Neal
Old Mar 17, 2010 | 08:42 PM
  #72
mds3013's Avatar
mds3013
Old Mar 17, 2010 | 08:49 PM
  #73
enroberts's Avatar
enroberts
Originally Posted by mds3013
I agree!
Old Mar 17, 2010 | 09:05 PM
  #74
Mike Ward's Avatar
Mike Ward
Originally Posted by 08vycpe
Are you sure you have the correct diameter hose?
From post #8 way up above. There was another member who had the identical scenario last year.
Old Mar 17, 2010 | 09:11 PM
  #75
enroberts's Avatar
enroberts
My apologies. I guess I just overlooked this and assumed that since the website I ordered the rad and hose from said they were both for a 77 corvette they would match. You know what they say about ***-u-me(ing). Anyway, thanks. -Neal
Old Mar 17, 2010 | 09:23 PM
  #76
noonie's Avatar
noonie
Bet you're glad that is it.
You can now consider yourself an expert hose installer.
Old Mar 18, 2010 | 08:32 PM
  #77
enroberts's Avatar
enroberts
Yes...very relieved. And lucky me to be called a hose expert. I guess I can retire at 27 now.
