fuel pump ?
Old Apr 4, 2010 | 05:25 PM
1977vette's Avatar
1977vette
Default fuel pump ?
ive never changed out a fuel pump, but was wondering if the hoses were connected wrong. what would be the result of that. any pics or info on what hose goes to which
Old Apr 4, 2010 | 06:56 PM
7T1vette's Avatar
7T1vette
Well, if that happened, it would take about 2 seconds for the pump to shoot what's in the carb back to the fuel tank. As it sits on the vehicle, the larger [rear] line is the inlet line from the tank; the smaller [front] line is the return line back to the fuel tank (if your car has that pump); and the line from the brass fitting goes to the carb.
Old Apr 4, 2010 | 07:41 PM
Duke94's Avatar
Duke94
They are different size hoses. Hard to mix them up.
Gary
Old Apr 5, 2010 | 04:39 PM
1977vette's Avatar
1977vette
cool! thanx guys! its on correct. just wanted 2 make sure
Old Apr 5, 2010 | 06:02 PM
phclub's Avatar
phclub
New England Events Coordinator
Anyone have instuctions on how best to replace the frame to pump lines without empting the tank?
Old May 2, 2010 | 06:15 AM
TeaEye's Avatar
TeaEye
Default Fuel Frame to Fuel Pump Hose Change
When I recently pulled the engine from my Vette, I had to separate the frame fuel hoses to the fuel pump. I had about 1/2 tank of gas.
Since you are asking the question, I'm assuming you wanted the longer version. Likewise, I encourage other members to critique my comments.
Below is Not an endorsement, nor a recommendation on how to do the task. It is just a recap of how I accomplished the task. Working with gasoline is a dangerous task and can cause serious injury/loss of life and damage to property.
WARNING:
Before I started! Safety wise, I did an assessment of my area to ensure there were no sources of ignition. Gas vapors are flammable. I had a fire extinguisher handy and also opened the doors and windows to ensure ventilation. If my garage had a gas water heater with a live gas pilot, I would have shut it down and made sure the pilot was out. I also looked for and eliminated All open flames and sources of ignition; no trouble light under the car where the fuel can spill on. Car battery disconnected. I even disconnect my air compressor to ensure a spark is not made when fuel vapors are present. Knowing static electricity can ignite gasoline, I goggled "static electricity hazards" and abided by the precautions. Also had my wife with me just in case I ran into a problem, dropped something and as I kept my finger on the open fuel line, she could pass me whatever I needed. I used Nitril gloves to protect my hands. Best Bet, If I were just changing the fuel lines, I would do the task in the driveway away from the house/garage.
1. I removed the clamp from the hose and lightly pried the hose end to ensure it is not stuck/frozen to the fuel line. If stuck, I use a pair of pliers and give a twist. To free some stubborn hoses, I pry up a corner of the hose and shoot some WD-40 and them twist to free them. If really stuck, I may need to do this a few times. Also an alternative to the pry and twist method, in the past, I have sliced the end of the hose and peeled the stuck hose off.
2. I prepared in advance what I was going to plug the frame fuel line once I was ready to remove the hose. Also, I placed a drip pan under the fuel pump to catch the fuel that will be leaking out. I chose to use vacuum plug ends. To be extra safe, I could even put a clamp on the vacuum plug. I made certain, I had the correct size. I even have a back-up vacuum plug or fuel hose with a bolt in it ready in case I dropped one.
3. Then I just removed the hose and plugged it. It is not under pressure. Making sure it is not leaking.
4. Once the fuel feed line is caped, I replaced the two hoses. Residual fuel from the fuel pump and my in-line fuel filter drained into the drip pan. Yes, I had the car on a jacks and tire removed for good access.
5. I placed the fuel in the drip pan into a gas container and took to my hazardous waste recycling center.
To fuel pump ?
