I have exactly the same carb on my 454 engine, it was rebuilt by Lars a while ago and since then it works really good. but isn't that carb too big for a small block?
Well this is the nice thing about Qjets, because they are metered fuel delivery and they have down draft controlled secondaries they can adapt to most V8 sizes, you just need to use correct primaries and rods for the setup.
Exactly. The Q-Jet is self-regulating on the secondaries...the air valve opens 'as needed' by the air flow going into the engine. So, while every Q-Jet has the potential to supply 750-800cfm, only the amount needed by the engine will be delivered.
All that is needed is to set up the primary jets and rods and the secondary rods, and to adjust the air valve spring to accomodate your engine's needs and it will work fine.
All Q-Jets are 750 cfm, whether they came off a small block, big block, or a 6-cylinder (yes, GM used 750 Q-Jets on 6-cylinders). The only exception are a few 800 cfm Q-Jets that were used on SD455 Pontiacs, Stage 1 455 Buicks, 500 cube Caddys, and late-70's 400 Pontiacs.
On q-jet equipped 400 cid first gen Firebirds, the baseplate would allow the secondaries to open to only 70% at WOT, which meant a max flow of about 600~ cfm. This 'governor' was to prevent the Firebird from exceeding GM's policy of no more than 10 HP per 100 lbs. for it's cars back in the day.
Also, GM thought the q-jet would work fine on the 327,..many were equipped that way; the L-30 for instance.
FWIW
