spare tire cover refurb
Old May 3, 2010 | 04:15 PM
kapla74's Avatar
kapla74
Default spare tire cover refurb
I´m in the process of giving some life to the spare tire cover, the lower part thats visible from the back.
It needs some paint in the metal frame, and some work on the fiberglass.
So far I removed the metal frame, removed all rust and paint, and its almost ready for paint again.
The cover had some cracks, so I used fiberglass to patch them, It also has some scratches in the lower bottom were it sometimes hit the road.
Questions:
what colour should I use to paint the metal frame? semigloss black or flat?
Cover, I now it came factory with the gray and with the FB patern visible, also some kind of underbody black seal was given, (at list mine has some spots with it). I know I should have only cleaned it and live it bare, but due to the crack i had to do something to prevent it from falling appart.
I plan on giving some primer and then use some gray as close as the original ...
any thoughts?
I´ll try to post some pics of the work done so far..
thanks..
Old May 3, 2010 | 06:01 PM
7T1vette's Avatar
7T1vette
I have painted my spare tire tub semi-gloss black so that it really won't show that well. I want to keep the tub and the spare, but I'd just as soon folks behind me looked at the car...not the tub.
Old May 3, 2010 | 06:08 PM
Will's'74VetteL-82's Avatar
Will's'74VetteL-82
I have my spare tire carrier out right now and am interested in restoring it so i would love to see some pictures of the process of restoring yours!
Old May 3, 2010 | 06:16 PM
kapla74's Avatar
kapla74
Will shoot some pics tonight and post them...to bad I didns´t document them prior starting.
I won´t have a before and after, but a while in the process and finished work...
I was trying to find Benuk thread of his refurb a while a go, it was a nice job, but can´t seem to find it..
Old May 3, 2010 | 09:01 PM
JimT's Avatar
JimT
I repaired the tub on my '72, painted the tub flat black, then painted the steel rails red to match the car. I think it looks great, it adds a little color to the underside, and, I have received many positive comments.
Old May 3, 2010 | 09:51 PM
kapla74's Avatar
kapla74
any pic af that setup jim?
Old May 3, 2010 | 09:59 PM
Frogday's Avatar
Frogday
Everything under my car has a thick layer of undercoating, including the spare carrier. This is what mine looked like while I was removing the undercoat with aircraft stripper:
It was all virgin glass once I removed all of the undercoating - messy work.
Old May 4, 2010 | 08:29 AM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
I just did this job last year. The tub I bought was covered with about a quarter inch of blackout, road grime, tar, and anything else that builds up on those things over the decades. I cleaned the tub with gasoline, it took a loooooooong time, but when I was done, the tub was in very good shape. So, I sanded and painted the rails a satin black, and left the tub bare fiberglas. I think it came out fine, it's not perfect, but my car is a driver, so I don't sweat the little imperfections.
Old May 4, 2010 | 09:27 AM
79blue's Avatar
79blue
I painted the tub flat black and the metal black satin. Looks uniform.My 2cents.
Old May 4, 2010 | 09:30 AM
76yellow's Avatar
76yellow
I've done 3 so far...I clean them & paint the metal satin black & use 3M undercoating on the tub. They look great !
Old May 4, 2010 | 10:06 AM
TWINRAY's Avatar
TWINRAY
Gotta do mine - interested in the post
Old May 4, 2010 | 03:14 PM
Alan 71's Avatar
Alan 71
Hi,
I found that after cleaning up the tub as Frog and PKg suggested, spraying the bare fiberglass with semi-gloss clear gives the glass a nice even sheen and darkens it just a bit like I believe it was when new.
Regards,
Alan
Old May 4, 2010 | 09:49 PM
kapla74's Avatar
kapla74
well not much done yet but here comes some pictures so far...
had a crack there so I patch it with glass, now it needs some sanding
old repair PO did
bondo it
after all the repairs I'm not sure I will be able to leave it bare glass so I'll have to give some paint...
rivets
i got this ones that are close to the originals i removed..but really needs to be punch hard to mushroom them in place...
I may op to use pop rivets instead..
Old May 4, 2010 | 10:18 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Heres the link to mine, I did away with the rivets and threaded the rail and used large head machine screws coming from the inside so they didnt rub the spare. Backed them up with cap nuts because the metal of the rail is not thick enough for the screw to grab with any comfort.
Also used truck bed liner. I like it!
http://forums.corvetteforum.com/c3-g...her-vette.html
Old May 5, 2010 | 12:06 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Like Alan said, the tub is supposed to be bare grey fiberglass. I used grey MarineTex to make the few repairs necessary on mine, then sprayed with satin clear. Being you had to make such extensive repairs using both mat and resin, you really have no choice but to color the tub. Perhaps you can find a dark grey epoxy and try to expose some of the fiberglass strands after it sets.
Old May 5, 2010 | 04:55 PM
Will's'74VetteL-82
Nice job on the restore so far and thanks for the pictures. I didnt know these things got beaten up so easily, mine is in really good condition, no cracks or anything, but i do have to clean up the metal on mine so that is my current project while the car is away!
Will
Old May 6, 2010 | 04:04 AM
thegavel's Avatar
thegavel
I gave my cover a spruce up about 4 years ago
(painted with VHT black wrinkle finish and hand painted crossed flags)and wouldn't you know it, 2 weeks later -It cracked !!!!
As you can see by the pic it's taken a bit of a beating since.
I'll end up re-doing it ONE DAY (soon).
Gav
To spare tire cover refurb
Old May 6, 2010 | 05:02 AM
71406's Avatar
71406
I used semi-gloss black paint on the tub and rail and then assembled with pop-rivets. Once the rivets were installed I sprayed the entire assembly again semi-gloss black to cover the rivets.
Old May 6, 2010 | 05:18 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i chromed the metal part and 2pac the carrier. 5 years since i did that and still good
Old May 7, 2010 | 06:12 PM
kapla74's Avatar
kapla74
I got the paint so hopefully I will finish this during the WE.
for the metal frame I will use semigloss black after i give it a couple of coats of antirust primer...(only gloss antirust black paint available here...)
Fo the tub I will so the bed liner paint as jerry (l82shark) did, I even got the special spray gun to get that rugged finish.
Gave
I see your car runs as low as mine, I get my pipes always hitting speed reducer!!!
and also sometime the tub as you can see in my previous pictures...
