Power Steering Control Valve Play
Old May 4, 2010 | 12:13 AM
Trog's Avatar
Trog
Default Power Steering Control Valve Play
Have a 77 in my shop, things appear tight in the steering box, and idler arm. New ball joints, probably could use some tie rod ends but I'm not really seeing any play there. I notice fairly quick movement of the pitman arm from the steering box when I rock the steering box input shaft. However. the power steering control valve input where the other end of the pitman arm connects moves what I feel is quite a bit to either side before the drag link begins to move.
With engine off, how much movement should be in that control box input area? Should it be able to swivel an inch to each side? Power steering appears to function without issue but I am concerned about what is "normal" amount of play in this area.
Thanks!
Old May 4, 2010 | 01:09 AM
Peterbuilt's Avatar
Peterbuilt
Are you talking about where the pitman arm connects to the power steering control valve?
Old May 4, 2010 | 01:29 AM
Trog's Avatar
Trog
Yes. Car is up on a lift (4 post drive on), I reach up & turn the rag joint, pitman arm moves and the control valve arm (other end of pitman arm) moves quite a bit before drag link begins to move.
Old May 4, 2010 | 01:34 AM
Peterbuilt's Avatar
Peterbuilt
Did the same test on my 74 and the ball connection in the valve moves about 1/4 inch total. 1/8inch left or right of center. That's normal.
Old May 4, 2010 | 11:20 AM
7T1vette's Avatar
7T1vette
The 'play' in the ball stud on the P/S Control Valve is designed to be that way and must be so in order to work. That stud has a coiled spring next to it and the spring is connected to the shuttle valve in the control head. Movement of the valve signals the pressure to 'feed' the slave cylinder which results in powered movement.
In essence, applying force to the steering wheel puts pressure on that spring. When you quit turning the wheel, the spring relaxes and the control valve goes to 'center' position which removes any turning pressure from the cylinder.
That's the best I can do to describe how it works, but that 'play' in the control valve ball stud must be there if the system is to work as designed.
Old May 4, 2010 | 11:26 AM
Mike Ward's Avatar
Mike Ward
Exactly. There is no residual hydraulic pressure in system once the engine is shut off so the free play is normal.
Old May 4, 2010 | 05:23 PM
Trog's Avatar
Trog
I understand that some play is required & that is how the valve works (control is engaged). My real question is how much is normal & how much is excessive?
I did just check it again (as I am on site again)... Engine off the amount is 3/16 right & almost 1/8 left.
TIA.
Old May 4, 2010 | 07:00 PM
wombvette's Avatar
wombvette
TIA.
Forget it, its right.
To Power Steering Control Valve Play
