72 Blue Cert Label -Weights
Old May 4, 2010 | 03:42 PM
7T2's Avatar
7T2
1st Gear
Default 72 Blue Cert Label -Weights
I'm having a new driver's side door cert label made for my '72 'Vette(build 6/72). The original label is long gone, so I'm missing the weight info. Anyone know what the weight (gross/front/rear) numbers are for:
'72 coupe, 350 L48, A/C, 4-spd.?
Old May 4, 2010 | 04:20 PM
Bob Heine's Avatar
Bob Heine
Sorry, I don't know the weight of your particular car but I wasn't aware that the cert label contained that information. The cert label on my driver's door has the build month/year and the VIN. Here's a picture:
Old May 4, 2010 | 04:24 PM
Alan 71's Avatar
Alan 71
Hi 7T2,
I can only find the curb weight for the coupe... 3220 lbs. I don't see a weight with various options or a front/rear breakdown. I realize you do need it for 72 starting with January built cars. Sorry!
Regards,
Alan
Old May 4, 2010 | 06:56 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
My 72 convertible is GVWR 4000 FRT 1860 REAR 2140
from April 72. Don't know if this helps you at all.
Old May 5, 2010 | 02:35 PM
Alan 71's Avatar
Alan 71
Hi RH,
That's interesting; passengers are included too! I wonder why?
Regards,
Alan
Old May 5, 2010 | 04:01 PM
Ret.Horsecop13
Originally Posted by Alan 71
Hi RH,
Regards,
Alan
I don't know why, but thats what the label says. I'll try to get a picture up tonight.
Old May 5, 2010 | 04:19 PM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
I know that if you have A/C the front weight number is higher. mine is for a coupe with power steering,power brakes, no a/c.
Old May 5, 2010 | 05:02 PM
Ret.Horsecop13
Convertible, a/c, power brakes, power steering, 4 spd.
Old May 5, 2010 | 06:24 PM
Alan 71's Avatar
Alan 71
Hi RH,
Nice Picture!
It's interesting that it appears (compared to RV's) that the weight did vary. I wonder if it's just the difference between coupe/convertible or was it equipment too?
Thanks for taking the time to post your sticker.
Regards,
Alan
Old May 5, 2010 | 07:56 PM
Ret.Horsecop13
No problem Alan,
You would figure a convertible would be less. You learn something new everyday! So the answer to the original question posted is... every car was different depending on equipment so use an average I guess.
Old May 5, 2010 | 08:12 PM
rvazquez's Avatar
rvazquez
To everyone concerned, I just checked over at the NCRS technical board and Bryan who has the same car as I do but with A/C posted that his GVWR is 4010 with the front being 1890 and the rear being 2120. Thats 80 more in the front and 20 more in the back than mine for a total of 100 lbs for having the A/C option.
Hope this helps
Regards
Roy
Old May 5, 2010 | 09:31 PM
vettes4evr's Avatar
vettes4evr
Roy, I sent you a PM. I need to get a blue label made for my '72 LT-1 with A/C, P/W,P/S,P/B,Tilt.
Old May 5, 2010 | 10:16 PM
rvazquez's Avatar
rvazquez
PM'd you back
Old May 6, 2010 | 07:15 AM
bashcraft's Avatar
bashcraft
Hi RH,
Regards,
Alan
Because it's gross weight. If for some unknown reason it was put on scales and it was overweight, you could be fined. Just like trucks.
Old May 6, 2010 | 08:02 AM
ED DINAPOLI's Avatar
ED DINAPOLI
This is a certification Label from my 72 base motor coupe with AC, 4 speed, No PB or PS.
Ed
Old May 6, 2010 | 11:39 AM
oldsarge's Avatar
oldsarge
Don't mean to jump your post, but I am doing a 73 coupe, 454, auto with power everything and A/C, anyone got a pic, so I can match the numbers, for my new sticker, thanks.
To 72 Blue Cert Label -Weights
